Home -> Forums -> Construction -> Water -> construction of drinking water Bore well inside building area for security
Sat May 25, 2013Total posts : 1
C.Balakrishna
C.Balakrishna
Topic: construction of drinking water Bore well inside building area for security
Dear Sir,        Date    25 - 5 - 2013
                  I need your valued advice on the location of  Borewell.
I wish to have my Borewell drilled within my  building Area  so that I can
avoid  the possible tampering / pollution by miscreants or anti-social men
as my house will be far away from city ie in remote area in Tamil nadu.
So please inform whether I can construct my Borewell +  Pump within
my house near to North East  Corner as per Vaastu and also any suitable
place inside house      Regards   Thanking You   Balakrishna Chiruvandal
Sat May 25, 2013Post  #1
GULSHAN RAI GULATI
GULSHAN RAI GULATI
Dear C. Balakrishna g,
 To my best of knowledge as per vaastu guidelines , all under ground water structures can be best located on North , East , North-East directions and electrical related points can be located ideally in SOUTH-EAST directions for best results.
Good Luck.
1260
Is ground water from bore well suitable for construction?
Last answer on 9/9/2016 11:06:16 PM. by bhuvaneshwaran bn. Forum started by Sandeep
3163
APP membrane
13537
2616
COLUMN nd LOAD BEARING
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
10047
6531
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by S L Gupta (Civil Engg). Forum started by DK
2121
underground water tank
3601
How we Calculate Construction Cost
Last answer on 10/21/2014 10:35:00 PM. by JAI PRAKASH. Forum started by JEETU KALANI
2419
2703
home security systems
Last answer on 7/3/2020 10:55:36 PM. by S L Gupta (Civil Engg). Forum started by farrukh tahir
2762
1786
1533
Are you looking for Independent House And Villa For Sale in Chennai?
Last answer on 7/3/2015 3:31:58 AM. by JAI PRAKASH. Forum started by neetasharma570
3903
construction of 1st floor
3246
Building a house in Kolkata Rajarhat area few initial questions
Last answer on 2/15/2013 12:40:16 PM. by DK. Forum started by DK
5055
2302
Terrace water proofing
2006
3176
Sump construction
2138
Question Regarding Borewell
1967
Over Head Water Tank
2756
Salt water
3128
Importance of Water
10178
2494
1887
water tank motor capacity
2752
Submersible pump - Bore
2357
2548
Water for Construction
Comparison
Earthquake
Rugs
Rugs for Living Room
