Home -> Forums -> Construction -> Basement -> construction of hostle
Tue Jun 21, 2011Total posts : 1
eshwar
eshwar
Topic: construction of hostle
sir,
     i want to know that basement is good or bad, second this in this my plan where i can make the staircase for upper floor and basement . and for making 5 floor what type of steel and cement grade required.
thanks
ishwar(9379403431)
bangalore
Attachments: apan ghar-Model.pdf on Tue Jun 21, 2011,&n
Tue Jun 28, 2011Post  #1
Dear Ishwar
Basement provides extra space, where there is no water logging problem basement is good, you can take help from website gharexpert.com construction section where you find lot of informattion about basement,see article link given below.http://www.gharexpert.com/articles/Basement-1504/Basement_0.aspx
For staircase you should take help from Architect and use tor/ ribbed steel and use 43 grade cement. Also see the section of cement concrete for the help.
1823
Last answer on 2/8/2011 7:07:20 PM. Forum started by eshwar
23866
6099
What is construction cost
3089
2019
2299
1871
1783
1740
5793
Last answer on 8/20/2020 3:44:33 AM. by S L Gupta (Civil Engg). Forum started by mayank
2353
3879
2193
4949
6464
2224
1894
give me the detailed inner construction plan...
Last answer on 5/12/2014 12:40:44 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
2115
please,give me the full construction plan...
Last answer on 5/12/2014 12:39:42 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
9061
makan map
2774
17223
1993
2157
design of column
2281
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2797
1970
ffff
1872
4211
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
