Home -> Forums -> Construction -> Start Construction -> construction of multi storey building
Thu Aug 07, 2014Total posts : 1
Mohan Bhagwat
Mohan Bhagwat
Topic: construction of multi storey building
 I am an environmental consultant. I would like to know the  quantities of various raw materials viz. cement, sand, bricks, steel, water  and any other raw materials required in construction of  say 20 storeyd building with say apartment size of 100sq. ft.
This is required to estimate the environmental impact the construction of  similar high rise buildings have on the environment.
Pl. suggest me an empirical formula to estimate various raw materials  for multi storeyd buildings with specific number of storeys or with say specific number of dwelling units with given floors.
Thu Aug 14, 2014Post  #1
Dear Mohan
          There are many books or material for detail of quantity of construction items, these also printed in states PWD OR CPWD SHEDULE OF RATES.Some are as under
1. c.conc.1:8:16 for 1cum= cement= 1.8 bags, sand .5 cum, brick or stone ballast= 1cum
Brick work 1:7 ratio for 1cum= cement=1bag, sand .25 cum, bricks= 480 nos.
2005
1650
804
1787
Dear team, Construction for the residential multi story building is in progress
Last answer on 11/14/2015 12:34:24 AM. by JAI PRAKASH. Forum started by Satheesh
3083
3368
3878
Reg planning & construction of 5 storey building in 50x60 site in bangalore
Last answer on 7/19/2011 3:32:31 PM. by palas. Forum started by Harsha
2164
want to built double storey in foundation of 2ft.abv. gnd.level,is it possible?
Last answer on 10/19/2012 12:02:07 PM. by S L Gupta (Civil Engg). Forum started by ashish
2252
2254
Sreel pillars(post)
4650
3793
1726
Want to construct commercial building in 3200sqft land.
Last answer on 10/8/2013 3:46:26 PM. by S L Gupta (Civil Engg). Forum started by sudheer
1889
Looking for a CIVIL consultant
Last answer on 11/14/2015 12:33:25 AM. by JAI PRAKASH. Forum started by Satheesh
2325
Materials
2365
Multi Purpose House construction
Last answer on 7/4/2020 12:14:37 AM. by S L Gupta (Civil Engg). Forum started by Asif
4254
2267
Hi, Having a plot of 30x50 facing road 53 degrees from north, so assuming northe
Last answer on 3/12/2014 2:46:09 PM. by satishb. Forum started by satishb
6099
What is construction cost
3309
2133
2059
Comparison
Earthquake
How to Design a Garage
Orientation
Orientation of Building
