Home -> Forums -> Construction -> Start Construction -> construction queries
Sat Dec 01, 2012Total posts : 2
aammiitt
aammiitt
Topic: construction queries
Hi Gupta sir!
1) which is better....
cement pain or dry distemper pain for exterior walls in Dehradun where we get a lot of rain cost wise and protection wise? Do they stand good in comparison to things like Apex / Ultima etc...similar paints?
2) what cost difference does mosaic and tile(using rs.50 per sq.feet tile) flooring has?
3) cost of stone chips for mosaic flooring? how much amount needed per square foot? what is the basic difference between mosaic and terrazzo florring in terms of look and costing?
4) one of your info section (http://www.gharexpert.com/articles/Counter-Tops-1317/Kitchen-Counter-Tops-Part-1_0.aspx) says that hardwood kitchen counter would cost less than stone, granite, solid surface or tile. Is this true? what hardwood in india are you talking about? what will it cost per square foot and how to fit?
Amit
Wed Dec 05, 2012Post  #1
Dear Amit
1.Cement paint is better than Dry distemper. The Acrylic exterior paint apex ultima is good for exterior surface.
2. The cost of mosiac floor is Rs 35-00 to Rs 40-00 per sft where as Rs v50-00 basic rates tiles  the complete rate comes out to be Rs 80-00 per sft. These both rates are exclusive of base coat.
3. Mosaic and Terrazo flooring is same floor.
4. Hard wood is the wood such as Hollac wood, seaseem wood, keekar wood etc and these planks after finishing by carpenter can be fixed for counter top and finished with either paint or laminated or finished with fixing thin seat of aluminum.As you stated that our article says it is cheap this is true but in the article next line  is that it damaged by water and get stain after some time. Actually In rural area where we have counter top of wood have not use water on that top and use them to store articles on that tops. Now i think it is clear to you.
A wooden top is long lasting if it’s sealed and installed properly. Hardwood tops are usually costlier than laminate but it is less expensive than stone, granite, solid surface, tile or steel. The top has some drawbacks because it can be damaged by water and get stains after some time.
For more clarification if any than write to the gharexpert forum and you will get the Answer.
Sat Dec 29, 2012Post  #2
atlantaroofingcont
atlantaroofingcont
Post subject: Atlanta Roofing Contractors
Interesting post.
2422
1790
like an answer to my query as it is important.drsingh
Last answer on 9/5/2010 11:55:20 PM. by Gunjan Utraja. Forum started by dr singh
1640
sir i have a query how can i contract
Last answer on 1/10/2016 8:48:39 PM. by JAI PRAKASH. Forum started by VINAY
2572
sir i have a query how can i contract my email id is vsp106@gmail.com
Last answer on 10/11/2021 4:59:19 AM. by JAI PRAKASH. Forum started by VINAY
2980
Query regarding Estimation and details required for swimming pool construction
Last answer on 12/28/2011 10:10:25 PM. by Edward. Forum started by Mukesh Singh
1788
Dear team, Construction for the residential multi story building is in progress
Last answer on 11/14/2015 12:34:24 AM. by JAI PRAKASH. Forum started by Satheesh
1889
Looking for a CIVIL consultant
Last answer on 11/14/2015 12:33:25 AM. by JAI PRAKASH. Forum started by Satheesh
2016
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Last answer on 5/5/2014 2:31:18 PM. by PR Jawahar. Forum started by Anurag
28626
Cost of Construction of boundary wall for vacant plot
Last answer on 7/23/2014 3:21:27 PM. by MANJUNATH. Forum started by Tejpal Singh
2835
Sunmica query
Last answer on 4/18/2018 1:10:51 AM. by Navneet Jharia. Forum started by Siddharth Gupta
2221
Last answer on 5/24/2021 4:53:02 AM. by Abhishek Garg (Builder & Engineer). Forum started by vamsi
1842
Problems,Queries and Suggestions from members.
Last answer on 12/31/2020 1:54:38 AM. by Kanhaiya. Forum started by Tip Master
1901
Column projection/Technical query
Last answer on 3/18/2021 3:16:35 AM. by JAI PRAKASH. Forum started by Pooja
1692
Query if the plot size is good for constryuction
Last answer on 3/5/2016 10:34:16 PM. by JAI PRAKASH. Forum started by NIRMAL
Query
Last answer on 10/30/2014 6:53:45 PM. Forum started by hemant
2508
Query reqarding Foundation & Tie Beam
Last answer on 1/10/2015 12:32:04 PM. by S L Gupta (Civil Engg). Forum started by Gian Prakash
2382
query for Marble
Last answer on 1/2/2021 5:28:10 AM. by S L Gupta (Civil Engg). Forum started by simran
1974
Dear Readers, I get a lot of queries regarding toilets in the centre of the hous
Last answer on 7/4/2020 3:06:40 AM. by seema tyagi. Forum started by VastuMoorthy
9159
3312
2236
2312
2061
