Home -> Forums -> Construction -> Ground work -> construction of second 7 third floor
Mon Dec 31, 2012Total posts : 4
kiran kumar 3k
kiran kumar 3k
Topic: construction of second 7 third floor
Sir I want construct two floors building on the existing first floor, but the problem is that the existing contractor has not left column rod after first floor. The structure should be of column structure only.
Tue Jan 01, 2013Post  #1
Dear Kiran Kumar
                For this problem dismantle the top of columns and remove the cement concrete from the steel bars on top of the columns for  at least 6''. Then you place new bars in the area just cleaned making U AT COLUMN and weld these new bars made U  with the old bars. Similarly weld the other bars and use cement concrete 1;1.5;3 in RCC work. It is a technical stuff so make sure you take the advise of a structure engineer at the site.
 BUT I am in view that at the time when you construct the old building than you probably did not make the foundation strong enough to hold the weight for four story building. If that was the case then the old foundation may not be able to take the new load. Before starting work make sure that your old foundation is able to take the load of four story building.
For this please contact any structural engineer of your town or city, who after visiting the house will verify whether the foundation is fit for four story or not and also give solution at site for column.
Tue Jan 01, 2013Post  #2
atlantaroofingcont
atlantaroofingcont
Post subject: Atlanta Roof Contractors
Tue Jan 01, 2013Post  #3
kiran kumar 3k
kiran kumar 3k
Firstly S L Gupta sir I am grateful for ur kind reply, the building was designed for four story due to some problem we could complete, now not a problem. one of my friend structural engineer suggested me by drilling holes in the existing beams to required depth & inserting required rod into holes filled with some lockset, proceed with the work as per the designed plan. Sir I am not able to understand what he is telling about lockset material, sir what is ur opinion/suggestion.
thanks & regards
Kiran Kumar 3k
Wed Jan 02, 2013Post  #4
Dear Kiran Kumar
          You should take all the details from your friend, who is structural engineer.
2061
1397
Options for construction of staircase in east facing two duplex houses where the
Last answer on 9/15/2017 2:56:37 AM. by S L Gupta (Civil Engg). Forum started by Sandeep endla
1191
I have an area of 1944sq feet in this I want graden and three floors house gron
Last answer on 4/23/2018 11:19:21 PM. by S L Gupta (Civil Engg). Forum started by Dilip Teja .G
1822
Plot size 25*50 please send construction plan for combined family with three cou
Last answer on 5/26/2016 3:34:41 PM. by Beenu Phogat. Forum started by praveen solanki
2490
1506
SirI have a 60-52 feet vacant site I would like construction ground and another
Last answer on 3/23/2016 3:43:42 PM. by S L Gupta (Civil Engg). Forum started by SUDHAKAR
3300
Last answer on 8/11/2017 2:13:58 AM. by HOME. Forum started by Mitesh
1853
Last answer on 12/24/2015 4:17:23 AM. by JAI PRAKASH. Forum started by paramesh
2517
i have three brothers iam the elder one so which floor i have to take
Last answer on 12/26/2016 1:06:41 PM. by S L Gupta (Civil Engg). Forum started by mrajireddy
3322
Last answer on 12/4/2020 3:40:06 AM. by juhi. Forum started by jeetendar
2906
I have 50X40 builtup areas with ground floor and want to make 1st floor but not
Last answer on 10/23/2012 11:46:28 AM. by Gunjan Utraja. Forum started by prabha
3623
1768
17223
1000
Hi All,I own a 30*40 plot whose width is 30 feet and length is 40 feet.Can you p
Last answer on 7/4/2020 3:51:13 AM. by S L Gupta (Civil Engg). Forum started by MeghaShyam N C
2634
New Construction in 40 width 70 length west facing plot
Last answer on 2/27/2015 4:07:48 AM. by JAI PRAKASH. Forum started by Ramesh Mayakoti
1871
1989
11990
Last answer on 1/5/2022 9:03:47 PM. by S L Gupta (Civil Engg). Forum started by ajay kalra
2995
8160
software
3900
2730
1833
lanterns
3134
false ceiling
2245
about construction
1786
4153
Cement Coba
3076
Water Harvesting System
1676
1758
water tank
2058
1760
1634
Pool construction cost
1994
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
Tips for Oil Bound Distemper
