Home -> Forums -> Construction -> Ground work -> construction of underground tank
Sat May 21, 2016Total posts : 1
sumit
sumit
Topic: construction of underground tank
I WANT TO KNOW ABOUT THE CONSTRUCTION OF UNDERGROUND WATER TANK  WITH DETAILS.
Thu May 26, 2016Post  #1
Dear Sumit
        The following operations are executed in under ground water tank.
1. Do excavation up the required size
2)  On dry and leveled ground 75 to 100 mm thick lean concrete is laid to serve as a leveling course
2 This layer should be protected by construction of flat brick flooring.
3) After construction of   bed lay structural slab and  side walls,
4) Before back filling the soil an outer protective wall leaving a space about 100 mm around should be made and the space should be grouted subsequently.
Ground work-Construction Questions (38)
5056
2188
2483
3120
2634
2119
5207
2451
2972
Location of Septic tank
Last answer on 6/4/2021 2:20:12 AM. by shadow. Forum started by PR Jawahar
2205
My house is under construction kindly advice the position of septic tank.Option
Last answer on 9/7/2010 5:46:10 PM. by sabina vanjani. Forum started by piyu sur
1596
IS THERE ANY DIFF. IN CONSTRUCTION CHARGES WITH MATERIAL FOR MUMTY , SEPTIC TANK
Last answer on 10/20/2016 12:44:55 PM. by S L Gupta (Civil Engg). Forum started by ANIL AGRAWAL
1906
Last answer on 10/7/2020 10:22:43 PM. by S L Gupta (Civil Engg). Forum started by siva
2253
2219
2121
1593
I have an underground water tank at the northwest of my house which is not recom
Last answer on 9/13/2010 4:25:10 PM. Forum started by Asha Khaitan
2540
underground tank
Last answer on 2/26/2013 8:10:29 PM. by Pavan. Forum started by Subramani P
1794
Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
Last answer on 10/25/2013 12:34:54 PM. by S L Gupta (Civil Engg). Forum started by Viral
2138
Last answer on 12/30/2013 2:23:18 PM. by S L Gupta (Civil Engg). Forum started by niyaz madiwale
2998
8161
software
3900
2730
1833
lanterns
3134
false ceiling
2245
about construction
1787
4154
Cement Coba
3077
Water Harvesting System
1677
1758
water tank
1761
1634
Pool construction cost
1996
2738
Regarding roof beam
Fire Stair case
2646
2374
super structure
Vastu for Water Tank
Preventive
Sewerage
Sewerage & Plumbing System
