Home -> Forums -> Construction -> Water -> construction
Sat Jun 16, 2012Total posts : 1
vnkesavan
vnkesavan
Topic: construction
Friends,
              Given that all parameters are equal,how is it that the same overhead water tank in a multistory building with two outlets at the same level (except that one side caters to more flats) gives water for more duration to the side catering to lesser number of flats. How can this be rectified   vnkesavan
Mon Jun 18, 2012Post  #1
    You state that at same level and same dia out let pipe, one is supply more water for long period and other supply less. Please call good plumber and check air vent pipe of lesser side.
Water-Construction Questions (31)
23866
6099
What is construction cost
3090
2020
2300
1871
1784
1740
5793
Last answer on 8/20/2020 3:44:33 AM. by S L Gupta (Civil Engg). Forum started by mayank
2354
2194
4950
3880
6464
2224
1895
give me the detailed inner construction plan...
Last answer on 5/12/2014 12:40:44 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
2115
please,give me the full construction plan...
Last answer on 5/12/2014 12:39:42 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
4807
3574
construction current rate
3177
Sump construction
2139
Question Regarding Borewell
1967
Over Head Water Tank
2756
Salt water
3129
Importance of Water
10179
1887
water tank motor capacity
2754
Submersible pump - Bore
2358
2548
Water for Construction
