cost of RCC ceiling plaster repair due to spalling
Sun Oct 05, 2014Total posts : 5
LM
LM
Topic: cost of RCC ceiling plaster repair due to spalling
Hello sir,
This query comes under repair/renovation.
We reside in the last floor of an old building. The ceiling is spalling in many places and chunks of ceiling plaster are getting loose and falling, and the reinforcement is exposed.
What is the cost of repair of this ceiling plaster? and how?
While renovating does the cost of plaster on brick masonry, vary from plaster on RCC?
Does the cost of breaking plaster on brick vary from breaking plaster on RCC?
Your reply would be most helpful in estimating the budget for rennovation. Thank you.
regards, LM
Sun Oct 05, 2014Post  #1
The budget can not be possible as the entire area doesn't require the repair work. Please hire labour and do it yourself as it look like difficult but its not.
Sun Oct 05, 2014Post  #2
LM
LM
Post subject: cost per sft of RCC ceiling repair due to spalli...
thanks for the response. The query is misunderstood. I am not asking for the budget, but for the cost per sft of ceiling plaster repair ( where loose chunks of the slab have fallen and the reinforcement is exposed) and if the cost of that would be more than regular plastering.
Mon Oct 06, 2014Post  #3
Dear LM
    As described by you the problem of falling of ceiling plaster is a serious matter to be repaired as soon as possible.This problem arise due to salty water use in the construction, fine sand used in roof and dampness in roof.In this problem MS steel used may be rusted now do the repair with the help of skilled  mason
Remove mortar
The mortar should be removed from cracked  portion and joint with the help of iron tools at least up to 25 mm depth. All loose material should be cleaned from cracked portion.
Wet the surface and apply cement mortar
Cracked portion must be kept moist at least for 24 hours before doing repair. Fill in the cracks and  joints with cement mortar of coarse sand in 1:4.
Do curing and finishing
After filling the joints with cement mortar, keep the repaired surface wet at least for 3 days. After drying the surface, finish the repaired area according to the adjoining area.
Caution;- DO NOT USE FINE SAND.
The cost is more than the regular plastering.Do the work with daily wages not on contract.
Mon Oct 06, 2014Post  #4
LM
LM
Post subject: cost of RCC ceiling plaster repair due to spalli...
Thank you sir.
Our contractor is quoting about 125/- per sft. Is that a reasonable sum. what should one expect in that amount, apart from cement mortar. This is working out to a huge sum.  pl suggest.
Tue Oct 07, 2014Post  #5
Dear LM
           As already suggest by me and Sh Jai Parkash that you should do the work with daily wages, Please hire labor and do it yourself as it look like difficult but its not.so difficult hire one skilled mason after he arrange every thing himself and do the work with good quality, contractor often not doing work up to the mark. The rate is very much on hire side.
Cost of RCC ceiling plaster repair due to spalling
Last answer on 10/6/2014 12:46:05 PM. by S L Gupta (Civil Engg). Forum started by LM
2521
construction const
6580
35210
1738
weather proof repair reg
2204
2924
1878
column
1598
Last answer on 1/5/2022 8:30:54 PM. by S L Gupta (Civil Engg). Forum started by Pranav
2642
False ceiling
Last answer on 4/24/2014 7:46:18 PM. by PR Jawahar. Forum started by PR Jawahar
10883
how much will it cost to construct a false ceiling
Last answer on 9/15/2021 9:50:00 PM. by ravi at Dalmia. Forum started by Vijayaraj
2453
can you tell me how much cost goes for galaxy ceiling decoration
Last answer on 5/2/2010 8:37:50 AM. by Ajit Tareeka. Forum started by Rahul S Chopade
3289
what material is used in ceiling other than plaster of paris?
Last answer on 6/1/2011 11:32:44 AM. by P. Panchal. Forum started by GURJEET
2713
Kids room ceiling designs
2918
Lumpsum constraction cost of smal home in RCC lock
Last answer on 1/18/2022 2:25:39 AM. by S L Gupta (Civil Engg). Forum started by neelkanth purohit
3475
labour charges rates
2414
COSTING AND STRENGTH OF WALL
How To Repair Cracks
How to clean plaster ceiling?
Gypsum
Plastering
Plastering
Ceiling
Ceiling
Ceiling designs
