Thu Jan 10, 2013 | Total posts : 2 |
| Topic: cost for construction for a new home
Dear sir, My self sapan giri. I have planed to build a home at
balesore,orissa, India in a area of 1200 sqft only ground floor with
three bedroom,common hall,comon kitchen,comon batroom,common toilet,one
puja room.
Plot size is square up to size 50*50 sqft. Can you help me about drawing and cost calculation with column & rcc means full work up to finished.
what will be the construction cost per sqft.
with best regards sapan giri
Articles that might interest you! | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | Home Construction Safety There are several home construction safety tips which can be applied during construction of the house. This article wi.. | | Happy New Year 2009 GharExpert.com wishes you a Happy New Year. It’s a special occasion to celebrate and dance with friends and guests enj.. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | List of construction activities in sequence Before going for any construction do you know what the sequence of construction activities is? Here is a list of const.. | | Stair construction-Things to remember Stair construction needs major consideration while you are either building a new home or just doing any renovation. Th.. | | Are you constructing a cupboard, Learn the difference between wood-only and wood-brick cupboards Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and W.. | | Vastu for Construction of House If you have bought a land/plot which is not as per vastu, you can amend it by making proper construction and using pro.. | | Construction of Brick Pillars The brick pillars should be designed according to the weight coming on it.
| | Installation Precautions for Wooden Flooring Installation Precautions are compulsory to make wooden flooring long lasting. If You do not follow these precautions, .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
