Home -> Forums -> Construction -> Start Construction -> cost of construction in hyderabad for 80 sq yd
Mon Oct 26, 2015Total posts : 2
vijaymavarapu
vijaymavarapu
Topic: cost of construction in hyderabad for 80 sq yd
I am planning to construct a house in area 80 sq yd in hyderabad.  Whtat would be total cost of construction for one floor. and is it better to contract the whole construction or should i suply material and get the labour on daily basis(no contract).  Pls advise.  Thanks in advance
Mon Oct 26, 2015Post  #1
It will cost you 7-8 lac's per floor all inclusive in good material.
Tue Oct 27, 2015Post  #2
Dear Vijay
          It is better to if you arrange the material yourself. let out the work on labor contract. If you have enough time than do work on daily wages. The cost is depends upon the specification and design of the house. However approximate cost is Rs 900 to 1000-00  per sqft .
1931
need help/advice to construct residentail house on 100 sq yd plot in hyderabad
Last answer on 2/21/2017 12:44:08 PM. by S L Gupta (Civil Engg). Forum started by Kamal
1397
Options for construction of staircase in east facing two duplex houses where the
Last answer on 9/15/2017 2:56:37 AM. by S L Gupta (Civil Engg). Forum started by Sandeep endla
2745
23866
3065
what will be the cost of this cieling if constructed in hyderabad
Last answer on 12/31/2020 2:46:32 AM. by hazariv. Forum started by ateeq
2665
plan for new construction 182 sq yd corner plot
Last answer on 1/10/2013 12:03:02 PM. by sonigupta. Forum started by kumarnaveen27
3597
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
3542
Contruction Tool
2706
type of brick
8582
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
2882
2557
2253
2224
6099
What is construction cost
2742
Cost of construction
Last answer on 5/10/2014 1:21:28 PM. by S L Gupta (Civil Engg). Forum started by awdhesh
3310
What is acre
Importance
