cost of materials
cost of materials
Thu Mar 16, 2017
arun kumar
Topic: cost of materials
COST OF MATERIALS AS PER PONDICHERRY
Sand
1 m³
Cement
1 mt
BG Metal 40 mm
1 m³
Steel
1 mt
Binding wire
1 mt
Bricks
1000 nos
Rough stone
300 nos
Bond stone
1 m³
Mixing mortar
1 m³
Convy of cement
1 mt
Centering charges
10 m²
Fabrication of grills
100 kg
Mosaic tiles
100 nos
Brick jelly
1 m³
15
Lime
1 m³
Pressed tiles
1000 nos
17
OBD
1 kg
18
Primer
1 kg
Cement paint
1 kg
20
Marble tiles
1 no
21
Teak wood
1 m³
22
Labour frame
1 m³
23
Labour panel
1 m²
24
Painting priming coat
1 m²
25
Painting two SE
1 m²
26
Mason I cl
1 no
27
Mason II cl
1 no
28
Mazdoor
1 no
29
Fitter
1 no
30
BG Metal 20 mm
1 m³
31
Conveyance of steel
1 mt
32
White glazed tile 150x150x6
100 nos
33
Chicken mesh 26 g
1 m²
Fri Mar 17, 2017
Dear Arun,
It is better to contact any hardware store and building material store at Pondicherry.
2843
lio
7216
2 lakh litre water tank
Last answer on 5/17/2016 1:30:52 PM. by
Shardul
1577
construction cost
Last answer on 9/26/2013 3:25:00 PM. by
sanket
1816
I want to construt 1200X900x50 mm chamber cover.what will be cost (material and
Last answer on 3/2/2015 11:59:21 AM. by
sachin kale
3790
Last answer on 7/3/2020 9:51:48 PM. by
Karan
v d nagar
2188
Last answer on 2/26/2013 11:21:26 AM. by
kamlesh
3832
comments required
Last answer on 11/18/2021 7:51:18 AM. by
gangula
1962
HOW MUCH COST WILL BE 3 BHK IN 1500 SQUARE FEET, PLEASE GIVE DETAILWISE MATERIAL
Last answer on 12/9/2015 11:40:05 AM. by
manoj
Building a 2 storey showroom in Moga, Punjab
Last answer on 1/5/2022 12:38:27 AM. by
gurdev singh
1784
can anyone suggest type and brand of wire and switches we should use for new res
Last answer on 11/26/2014 7:58:46 PM. by
Cost Estimation of Roof Slab with Beam Structure
Last answer on 4/24/2014 3:21:16 PM. by
serin
Subhajit Kundu
14519
demolishing old house procedure & cost
Last answer on 11/15/2012 12:55:00 PM. by
latha
2264
wall
Last answer on 12/12/2012 12:27:36 PM. by
saif
2519
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by
kamlesh
2393
labour
Last answer on 5/14/2013 3:14:12 PM. by
Kilyen Rampton
dan
1945
ITS GOOD AND I WOULD LIKE TO KNOW ABOUT THE MATERIAL AND ITS COST PER SQUAREFEET
Last answer on 12/20/2010 5:06:42 PM. by
ranjeetsaini
CORDIALINTERIORS
2308
can u tel me the material of this curtain n how much does it cost????
Last answer on 3/30/2011 4:41:55 PM. by
Nikita
rupali
2233
for wood work in kitchen please give some ideas about design & good material wit
Last answer on 6/4/2021 12:34:00 AM. by
nagaraja k.n.
2649
Curtain wall Glazing
Last answer on 9/5/2021 4:56:55 AM. Forum started by
ekonagu
2451
Specification of Brick
Which types of finishing materials are recommended for glass windows?
1.Glass Former: It is the primary material. 2.Flux: It lowers the melting temperature as well as viscosity. ..
