Home -> Forums -> Construction -> Start Construction -> cost saving in construction of house
Tue Sep 03, 2013Total posts : 5
raviprakash
raviprakash
Topic: cost saving in construction of house
Gupta Sir
Can we not save Residential building construction cost by implementing modern techniques and new methods of constructions apart from saving in material example:  instead of going for granite flooring using vitrified tiles and cement block instead of red clay brick etc………
Day by day it is getting difficult to construct a house for common man
Is there any suggestion from your end saving cost in construction of house without comprising on function and quality aspects.
Thanks and Regards
Ravi Prakash
Wed Sep 04, 2013Post  #1
Dear Ravi Prakash
                The cost of construction is mainly connected with the specification used in construction.There are many technical aspects if we follow than cost can be saved.
1.If we know the bearing capacity of soil, Then make economical design for foundation according to load coming on it.
2. If we have proper structural design of slab than thickness of slab can be minimise and there is saving in the MS steel bars. on the slab span of 10' we can use 10mm as main bars and 8mm as distribution bars thus saving in steel bars. In continuous slab end bars are 10mm and intermediate bars  to be 8mm.
3. By making 4.5'' wall where no load is coming save the cost.
4. If we have good finishing in plaster save the cost of putty filling.
  There are so many aspect if we follow during construction than cost may be saved.
Thu Sep 05, 2013Post  #2
raviprakash
raviprakash
Gupta Sir
Thank you very much for tyour valuable suggestion
Thanks and Regards
Ravi Prakash
Fri Aug 10, 2018Post  #3
Amit
Amit
Check on google about GFRG (glass panel reinforced gypsum) panel construction. This technology is becoming quite popular in Kerala , Karnataka and TN.
GFRG panel is available in size of 3m x 12M
it has cavity of 5.15 inch.. The whole wall is placed with Crains. Cuts are made for doors and windows and every 3rd cavity has micro beam of TMT steel and filled with M20 concrete. Other cavities are filled with filler material of query dust and 5% cement.
This is same composition as ACC block. Here wall needs no plastering and putty as the gypsum panel is smooth white material.
The construction time reduces to 90 days.
Cost reduction is around 25% mainly in finishing and labour.
Main disadvantages
- Carnes / manpower to handle technology should be available around you.
- Enough empty space around site so that boom crane can lift panels.
- Curved wall sections not possible pr need yo be built with blocks /bricks.
Here cost reduction is around 25% .
These panels are made by RCF Kochi and in Mumbai
In case you are far from these places and trained manpower is not available it may work costlier however of you are in South you can look at this alternative.
Search for GFRG and IIT Madras for more details.
Fri Aug 10, 2018Post  #4
Amit
Amit
Some more cost saving tips application to traditional construction as well.
These are environment friendly options as well. First engage a structural engineer for design and give labour contract dont go for labour and material. It will give you 10-15% advantage but you will have to invest your time.
1. Use AAC blocks or fly ash bricks instead of red bricks
2. Go for fresh stock of good local brand cement pay attention to grade (53 /48) type OPC/ PPC / PSC and manufacturing date instead of paying premium for brand.
3. Instead of PPC cement for 10rs less per bag for plastering buy OPC 53 cement bag for 10rs more and mix 20% flyash at site  you will save more money.
PPC is nothing but OPC with 30% flyash.
4. If you have RMC plant nearby go for RMC instead of site mix. You can ask GGBS (granulated blast furnace slag) and flyash M 20 design mix.  You will not have headach if contractor has followed correct ratio of water.
5. Go for M sand or even better slag sand. In small town India still contractors push for river sand which is 4 times costlier.
6. If you have option of factory cut and bent steel go for it. Pre cut and bent steel is delivered in exact quantity as per design avoids wastage and saves time and labour.
7. Go for good quality no big brandname Morbi tiles instead of big brands.  PGVT or double charged unbranded Morbi ( Gujrat) tiles are defiantly better then big brand ceramic /porcelain tile at nearly same rate.
8. If you have more budget for flooring finiah choose Indian granite or marble however never ever go for Italian marble even if you have money to splurge.
It is highly porous stone full of cracks thus full of epoxy and extra shine is of crystallization and diamond polish.
Ask for Crystallization  ( Lithium silicate based crustalizer ) and diamond polish on Indian marble you will get same mirror like shine but more durable and at a fraction of cost.
8. Go for flush doors with sal wood frame or WPVC if you are very tight on budget.
Do not go for teakwood even for main door. Instead of wasting a fine tree get 19mm flush door and teak vaneer and ask carpenter to give teak finish on both sides.
9. Do not unnecessarily splurge om elevation design keep it simple.
Mon Aug 17, 2020Post  #5
foro
foro
Post subject: save money in construction
You can save money in construction if you buy low-maintenance construction materials. Work with your contractor to source the right materials at lower prices which include locally available bricks, cement, etc. Old or reclaimed materials could also be used, particularly for staircases. You need professional construction services.
1783
6099
What is construction cost
2378
New house construction_Need help on saving cost
Last answer on 7/9/2012 10:54:51 AM. by Ar. Manoj Ralen. Forum started by ankush
1661
Is there any structural importance to sunshade?
Last answer on 11/3/2015 11:49:30 PM. by JAI PRAKASH. Forum started by Techman
2974
4647
3597
2354
what would be the cost of construction for this kind of house for approx floor o
Last answer on 8/21/2010 12:50:17 PM. by S L Gupta (Civil Engg). Forum started by bhavin
2593
JOINERY WORKS
2489
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
8581
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
1994
Sir I WANT TO KNOW THAT HOW MUCH CONSTRUCTION COST OF THIS HOUSE WILL BE EXCEPT
Last answer on 7/17/2013 11:42:13 AM. by S L Gupta (Civil Engg). Forum started by mahesh
1676
if we plan marbal/Tiles work later on after 2/3 year of construction of house i
Last answer on 7/31/2014 7:48:23 PM. by JAI PRAKASH. Forum started by dspatwal
3145
What are advantages and disadvantages of iron doors?
Last answer on 1/30/2010 9:20:41 AM. by S L Gupta (Civil Engg). Forum started by rajesh malik
19134
Solid cement block Vs Bricks
Last answer on 6/10/2012 11:29:35 AM. by jag2. Forum started by jag
4807
2679
3296
3309
2133
2059
Energy
Energy Saving Fans
Everyday rising energy demands reminds us to explore new energy saving devices. Energy saving ceiling fans is such a d..
60
60 Tips to Save Water
Energy
Energy Saving Tips
Saving energy will definitely help you minimize your energy/electricity bills. Here are some nice tips to save energy;..
Why
