Thu May 08, 2014
premkumarlen
Topic: cost varinece for pt slab and general rcc slab
Dear sir,
Pls tell construction cost varience for PT slab and rcc slab per sft,
Fri May 09, 2014
Dear Prem
Your query is not clear, write in detail and what you mean PT slab.
Last answer on 8/26/2020 7:03:47 PM. Forum started by
Jam Draw
9893
Last answer on 9/19/2020 12:43:29 AM. by
shaik khaja nayab rasool
rishi
191896
Last answer on 1/23/2022 3:32:01 AM. by
Bimlendra Jha
11827
cost of rbc and rcc slab
Last answer on 7/3/2015 3:43:36 AM. by
Bs Dhiman
4835
Last answer on 7/9/2020 10:10:27 PM. by
jptallam
2974
Last answer on 7/3/2020 10:59:48 PM. by
satyawan
3752
Last answer on 1/30/2017 12:00:36 PM. by
2293
Last answer on 6/16/2021 11:37:22 AM. by
dnyanesh
2407
Last answer on 8/5/2015 4:49:45 AM. by
sanjesh
1980
Last answer on 10/27/2015 10:43:31 PM. by
Baba Dedge
2865
lio
4807
Last answer on 7/9/2014 11:16:51 AM. by
nadim
4952
Last answer on 12/17/2016 11:39:42 AM. by
Satya
4010
labor rate for RCC work
Last answer on 7/28/2020 1:27:06 AM. by
ringwang
ringwang
1597
Last answer on 1/5/2022 8:30:54 PM. by
Pranav
2865
Steel calculation
Vamshidharreddy
1456
vishal Thakur
Cost of RCC Terrace slab and Colomns
Last answer on 6/10/2014 2:29:45 PM. Forum started by
a.monteiro
5860
Last answer on 11/13/2016 12:55:24 AM. by
srikanth
5810
Rakeeb Rathor
3791
Pandu
9883
nasad
2669
Sreedhar
4626
ani
4142
Anamika
2865
lio
5213
ringwang
R.Roy
5006
MANISH
3655
Arvind Bhaskar
1863
carmenjames
r.n.misra
2799
Sharath Kurva
Sharath Kurva
2609
gk
2372
Adriano Peres
vamsi
2462
nuksung
2637
dayal
1807
TUNDE
3607
ragha
6253
suba
Reasons of dampness
Garden Path Ideas
