Home -> Forums -> Construction -> Bricks -> costing calculation of parapet wall on roof
Sun Oct 21, 2012Total posts : 0
Sanjoy Kundu
Sanjoy Kundu
Topic: costing calculation of parapet wall on roof
Need to make Parapet Wall on roof.
My roof area is 62' x 23'
Want to make 3' high 10" parapet wall.
How to calculate the requirement of bricks and other material.
Pls help.
2054
6471
4109
4798
Last answer on 1/13/2014 2:23:28 PM. by S L Gupta (Civil Engg). Forum started by balaji
4331
1875
4648
1648
3293
7006
2193
PLEASE SEND ME NEW DESIGN FOR HOME WALL & ROOF 10X12 ROOM
Last answer on 10/18/2013 4:07:28 PM. by S L Gupta (Civil Engg). Forum started by PRAKASH KUMAR
2649
9196
2616
Exterior Walls
11568
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
1965
I have constructed my house thru one of local contrctr at the rate of 1300 per s
Last answer on 12/4/2014 1:21:13 AM. by JAI PRAKASH. Forum started by mani
2876
2169
can you suggest me the probable cost for onw wall of approx 10.5 X 12 Feet
Last answer on 11/13/2016 12:56:53 AM. Forum started by Lokesh Gupta
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2822
2350
3172
bricks
5660
2014
3238
5135
Use of Solid Concrete Bricks
1625
1341
1846
1480
1797
2967
fly ash bricks
2230
1724
Cooper
Roof Garden
Asphalt
Asphalt Shingles Roofing
