Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> crack in undergroun water tank
Fri May 25, 2012Total posts : 5
shabbir ali
shabbir ali
Topic: crack in undergroun water tank
dear gutaji,
                namaskar,
i have constructed under ground water tank with bricks walls & plaster with sand coarse & cement sallary two years ago, for last 4 month tank remained empty ,some  days ago  i had clean the tank when i notice a thin crack  vertical on  one wall of tank, please suggest how to repair this crack so that water does not leak.
                                                   thanks
Sat May 26, 2012Post  #1
Dear Ali
          In my view there is no use to repair the crack as it is due to settlement of wall. make wall rough and construct RCC wall with this old wall with light M S Steel bars. After lying RCC wall do cement plaster on the very next day including floating coat with cement shullary.
Sat Jul 21, 2012Post  #2
sam_m400
sam_m400
Sir
 I have many are buiding sump with bricks/mesh/water proofing, instead of going for RCC sump as it is very expensive . All claiming brick one may not have any leaks as many houses having the same for years. What is your suggeston Brick sump or RCC sump?
Sam
Sat Jul 21, 2012Post  #3
Dear Sam
It is right that brick wall sump is equally good. For constrution of sump do some care that
1. After excavation, compact the bottom of sump.
2. Lay cement concrete and compact it fully.
3. Construct wall either RCC or brick wall but brick wall should be 9'' thick not 4.5'' with cement mortar.It must be ensure that pipe should be laid during the masonary not after by bracking the walls.
4. Do cement plaster on both side and finish it with cement shullary on the same day .
5 lay the flooring and finish it properly.
6. Do curing for at least 7 days.
Sat Jul 21, 2012Post  #4
sam_m400
sam_m400
thanks sir,
1. What is plastering proportion of mortar to be used?
2.What is mortar proportion to be used in the floor of sump?
3. Do we need mesh ,as i have see a thin metal mesh being put along the wall during plastering? they say this mesh/water plastering will prevent any leak coming in future
Sam
Mon Jul 23, 2012Post  #5
Dear Sam
1.Ratio of plaster 1;4, 1cement and 4 coarse sand
Ratio of floor 1;2;4 , 1cemet,2 coarse sand and 4 bazri.
Use metal mesh.
2333
3370
2234
5055
2374
water tank
2185
2482
1727
1933
3119
7232
2 lakh litre water tank
1844
6271
Water Tank Quality
1886
water tank motor capacity
2388
3133
5207
2448
2633
1885
tap Connection
3627
sunken slab
2507
How to hire a plumber
3497
1675
2321
3860
flush toilet
1960
4721
Cost estimation for sump tank
2219
water supply
2042
Underground Water storage
2230
sewage pipes
2251
commode & flush type
1948
WC issue
5625
Over-Head water Tank
2337
Vastu for septic tank
2483
2474
Septic Tank Design
3753
position of septic tank
Vastu for Water Tank
Preventive
How To Repair Cracks
Reasons of dampness
