Thu May 20, 2010Total posts : 1
sudhir
sudhir
Topic: how the cracks can be prevented further which are developed due to pile failure
Fri May 21, 2010Post  #1
Dear sudhir
The pile foundation may be failing due to many causes i.e. due to earth quack, due to land slide, bending failure, shear failure etc. The pile foundation may be fail in liquefiable soil due to buckling instability, bearing failure, combined bending and settlement failure etc. For repair of cracks you should contact structural engineer who tell the methods of repair after inspecting the site.
1994
Minimum thickness of Pile Caps
Last answer on 11/6/2016 1:21:02 AM. Forum started by Pritam Thakur
1988
Cracks in concrete roof
3501
4034
3456
3220
Cracks developed in corner of walls
Last answer on 12/31/2020 2:46:05 AM. by Ajit Tareeka. Forum started by Munjal Shah
2726
Present interior design
Last answer on 2/8/2021 11:16:14 PM. Forum started by ENG
2510
PILING in a soft soil
Last answer on 7/9/2012 3:38:08 PM. by S L Gupta (Civil Engg). Forum started by mangeshghule
1652
crack in building
Last answer on 8/17/2016 11:59:29 AM. by S L Gupta (Civil Engg). Forum started by sunder
5134
Use of Solid Concrete Bricks
4291
Cracks in brick walls in 5th floor apartment
Last answer on 2/8/2021 8:45:31 AM. by singhvishal1689. Forum started by Raghu Kumar Akkala
2509
Pile Foundation
2705
How to fix cracks in my home
Last answer on 7/3/2012 12:04:18 AM. by Swati Satija. Forum started by vivek
2321
pile work
2234
2499
Reg: Cracks in cement brick walls
Last answer on 12/17/2013 12:32:00 PM. by S L Gupta (Civil Engg). Forum started by Dhananjay
2276
How To Repair Cracks
Avoid
Avoid Short Circuit
Avoid daily short circuit and overloading with the use of MCB(miniature circuit breaker), and save your electrical app..
Termite
Termite Damage Signs and repairing tips
Termite damage is a worst dream for any house owner. Termites eat wood and this affect almost every wooden product lik..
Which are various types of faults in electrical fitting?
These are three types of faults in electrical fitting: .Open Circuit Fault .Short Circuit Fault .Earth fault and ..
