Home -> Forums -> Construction -> Outdoor -> cracks in walls
cracks in walls
Tue May 25, 2010Total posts : 1
ndevendra
ndevendra
Topic: cracks in walls
We are getting a house constructed through a builder. The work commenced almost two years back. An year back walls were all constructed. 6 months ago lappam was applied to the walls. Now I see many cracks on nearly all the walls. Can some one suggest me how do i solve this problem.
Tue May 25, 2010Post  #1
Post subject: Dear
Dear ndevendra
Cracks in building are a common occurrence and these occur due to carelessness of contractor, mason, and ignorance of house owner and using of inferior materials in construction. It is important to understand the causes and the measures to be taken for their prevention.
                          Before doing any repair of cracks, make sure that the cracks are stabilized or not i.e. widening further and repair the cracks with the help of expert mason as per detail given in the article at the website gharexpert.com link given below.
http://www.gharexpert.com/articles/Cracks-1468/How-To-Repair-Cracks_0.aspx
for further more details you can read articles at www.gharexpert.com website.
and article link is:
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1371
Outdoor-Construction Questions (38)
2734
2344
3383
Recurring Cracks
4142
2900
2342
2507
2720
White stains in the walls and cracks in the walls
Last answer on 2/23/2011 9:05:33 PM. by Muralidhar. Forum started by Muralidhar
3000
2713
constraction details
Last answer on 1/1/2021 2:45:02 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
2930
2583
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell
2489
Exterior Wall Crack Repair
Last answer on 12/26/2011 7:13:39 PM. by S L Gupta (Civil Engg). Forum started by S. Kumar
2708
How to fix cracks in my home
Last answer on 7/3/2012 12:04:18 AM. by Swati Satija. Forum started by vivek
3394
1910
Last answer on 5/21/2013 8:56:40 AM. Forum started by Aji
2297
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by S L Gupta (Civil Engg). Forum started by Gagandeep
2504
Reg: Cracks in cement brick walls
Last answer on 12/17/2013 12:32:00 PM. by S L Gupta (Civil Engg). Forum started by Dhananjay
2870
Steel calculation
1763
6698
6368
11402
10747
Life span of RBC lintel roof
2093
Foundation
3574
R.C.C. column in Sqft
2282
Plumbing works
1594
2159
New 4 storey building design
1911
earth filling under floor
1777
want a parking
2408
2272
2566
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2639
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2507
Re-Construction
How To Repair Cracks
Which type of wall plastering is recommended for protection from the cracks?
To avoid cracks, Earthen Plastering is applied. Clay in Earthen Plasters is Hygroscopic (water absorbing). Earthen wal..
Surface
Canvas
Canvas Wall Art
