| Corner Bath Designs Corner bath ideas help you in saving space. There are lot fantastic styles that guide you to design your small space b.. |
Cracks at the junctions of Brick Walls and RCC slabs Handle the cracks in the walls initially because they can destroy smooth finishing of the plaster. |
| Protect your home from Dampness Dampness causes most of the damage to the contents of the building. It often leads to the growth of molds and bacteria.. |
| Bathroom Cabinets Bathroom wall and corner cabinets offer you the space to store different bathroom accessories. This article guides you.. |
Which are various methods for the protection of dampness in buildings? REPLASTERING: The most common method is to scale the affected damp plaster back to the brickwork and replaster the aff.. |
Reasons of dampness
The reasons of dampness in the building are following:
1. Bitumen /Tar- felt coat on RCC slab is not proper or is |
| Canvas Wall Art Your home definitely reveals you. It reflects your interest and your sense of colors. A splash of innovations and colo.. |
Which are various brands of chemicals used for the protection of dampness from building ? The following brands of chemical are used for the protection of dampness from building: |
Which type of DPC recommended for the protection of dampness? For residential buildings DPC consists of a layer of - 40 mm thick cement concrete 1:2:4 (1 cement: 2 Coarse sand: 4 g.. |
| Basement Walls Basement walls always needs special care because of outside pressure of soil. Read about What care should be taken for.. |
