Home -> Forums -> Construction -> Start Construction -> demolishing old house procedure & cost
Wed Nov 14, 2012Total posts : 1
latha
latha
Topic: demolishing old house procedure & cost
Dear sir,
i planned to demolish my old house to construct a new house there.
i spoke to building demolisher in bangalore regarding this,
they are charging 1,10,000 INR for The cost of demolition and debris transportation of your entire building is Rs. 1,10,ooo/- (Rupees one lakh and ten thousand only). If you are giving all the salvage materials like wooden, iron etc.etc. to us than we will minus the cost of materials from the above expenses. If there are wooden doors and windows in your building then the expenses to you is nil, and in this case neither you have to pay us any thing nor we. we will bear the cost of demolition and debris transportation by taking away the salvage items of the building.
Please suggest on this, the charge they are asking is acceptable, reasonable or not?
aslo is this good to sell my doors, windows along with all old salvage materials?
thanks in advance
Thu Nov 15, 2012Post  #1
Dear Latha
           Firstly to see that the roof of the house is of RCC roof or wooden batten and and tiles roof. If it is battened roof than see the condition of wooden batten and if they are good than can be use making wooden door and windows frame or may be sale in good price. In case of RCC roof then MS steel of good condition may be used in building lintels etc or sale in market.The same the case of door & windows.The old bricks used in the house can be used in foundation of new house and broken bri cks can be used in fondation concrete and under floors. The old house have low level flooring and now you have to raise the floor level in respect to new road or street height and keeping in view flood level then most of debris may be used to raise the floor level.
If you want to sale all than contact 3 to 4 contractor and give to higher bidder.
4648
3080
we want to demolish this old house and want to construct a new one. but the problem is there are neighbors whose walls are in touch with our wall so if we demolish and if their wall collapse then we will have to construct their wall also.. they are not ready to construct a new one. what is the solution..
Last answer on 5/20/2014 2:47:38 PM. by S L Gupta (Civil Engg). Forum started by vijay
3317
Last answer on 5/1/2012 11:09:41 AM. by S L Gupta (Civil Engg). Forum started by pankaj sharma
2603
Using old bricks for construction
Last answer on 11/3/2011 11:02:20 PM. by susandixon. Forum started by Col MP Singh
New Home
1868
Brick Pillar
Last answer on 7/9/2013 4:57:18 PM. by Binoy Rabha. Forum started by alefiya
1510
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
2337
Pls what are the procedures in doing this floor
Last answer on 5/23/2012 12:44:44 PM. by S L Gupta (Civil Engg). Forum started by lilian
2766
3075
What are the basic things that are needed while painting?
Last answer on 10/8/2010 11:47:06 AM. by Sazid Ali. Forum started by Sazid Ali
2664
procedure of building layout detail
Last answer on 3/15/2011 6:11:55 PM. by Mohini Sharma. Forum started by kanwer sajjad
6818
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by sugantha. Forum started by sukamalroy
1369
Need advice for constructing commercial building with a pent house
Last answer on 9/9/2016 11:42:58 PM. by bhuvaneshwaran bn. Forum started by Mini
14267
Demolition of Old house and constructing New house
Last answer on 1/21/2011 11:04:22 AM. by Archit Jain. Forum started by Kanchana
1646
Construction cost of 7 years old house
Last answer on 8/19/2013 11:32:32 AM. by S L Gupta (Civil Engg). Forum started by Syed HazratHussain
10722
Life span of RBC lintel roof
2925
3312
2236
2312
2061
How to Paint Old Furniture
Painting
Environmentally
Environment
Environment Friendly Houses
