How do I clean cement and brick dust created
Wed Sep 07, 2016
Satvinder kaur
Topic: How do I clean cement and brick dust created
How do I clean cement and brick dust created while drilling during renovation of ahome?
Thu Sep 08, 2016
These are the views of expert
Vacuums are a good idea while actually creating the dust. For clean up, keep it wet and sweep it up. Sweeping compounds like sweepsorb or other similar products can help to control the dust and keep it from becoming airborne. Always wear a dust mask or respirator if possible. Silicosis is a real hazard here. Silica dust is a danger of concrete dust especially. Look it up; the fine dust created when drilling, grinding, or chipping concrete can become lodged in your lungs and cause cancer.
<edit>
As far as cleaning brick and cement dust off of finished surfaces, I am not really sure. Painted walls, cabinets, floors, and finished woodwork require care to make sure you don't grind abrasive dust into the surface or drag it across, causing scratches. Super soft brushes and feather dusters or dust mops might be the way to go in that situation
676
Creating an Epayments wallet. How ? - Who has already done the registration and
Last answer on 9/7/2021 3:33:02 AM. by
olii fill
CrySmile
7512
Brick Advice Urgent
pmarple
pmarple
2645
MOHD WAKEEL
2657
Last answer on 3/4/2013 12:25:11 PM. by
nasad
nasad
3494
Last answer on 1/10/2012 10:27:59 PM. by
op kataria
Shrinivas
1789
What are the special characters of different kind of bricks.Size of a cement bri
Last answer on 1/28/2014 2:44:37 PM. by
Dilip
2990
3272
For Estimate
Last answer on 7/3/2020 11:21:15 PM. by
Bs Dhiman
1468
What is best method to clean GI Door frames after cement plaster is over. If har
Last answer on 7/4/2020 3:19:44 AM. by
Surinder Singh
Surinder Singh
2403
Last answer on 2/26/2013 11:22:44 AM. Forum started by
nasad
5577
Flooring
Last answer on 2/24/2022 11:40:25 AM. by
mike
swati
2336
Last answer on 9/19/2012 1:30:40 PM. by
r s rawat
mujahedsabb
2420
Last answer on 8/20/2015 2:23:19 AM. by
Gunjan
3603
What is the cheapest form of waterporoofing the terrace?
Last answer on 7/21/2012 3:35:37 PM. by
Vipul Hasija
2217
Last answer on 5/24/2021 4:53:02 AM. by
vamsi
3279
Bedroom Wardrobes information
Last answer on 7/3/2020 9:26:49 PM. by
Meenakshi
2415
Last answer on 10/20/2013 8:17:05 PM. by
sowmya
sowmya
2326
Last answer on 11/19/2013 1:31:03 PM. by
Toby Tyler
1788
how efficient is a dishwasher for indian style of cooking?does it clean cooker
Last answer on 10/16/2014 12:30:18 AM. by
neelam rathi
Bathroom Cleaning Tips
Carpet Cleaning Tips
Kitchen Cleaning Tips
How to clean plaster ceiling?
How to Clean Ceiling?
You can preserve the beauty of ceiling with regular cleaning. It keeps your room clean and ensures hygienic environmen..
Brick Arches
