how do one tackle cracks in the colum.
Mon Apr 19, 2010Total posts : 3
lekan akinwumi
lekan akinwumi
Topic: how do one tackle cracks in the colum.
At building surveying
we discover cracks along the colum of one of the corner of  two storey building. the crack move from ground to top, stopped at first floor balcony; it suggest that the balcony may collaspes if somthing is not done.
what is your opinion on this.
Mon Apr 19, 2010Post  #1
Post subject: Reply-Cracks
Dear Laken,
From your query, position of crack is not clear and you have not sent any picture of crack. In addition we want to know that how many years old your building is? There are many possibility of formation of crack i.e. weather the crack is in the finishing of RCC column such as in the plaster or the crack is in the side cover of steel provided in the column or on the top of steel bar due to not providing necessary thickness of cover on the steel bar at the time of laying RCC column or the rusting of steel bar is started due to various causes. You should take help from the articles of cracks given in the section of safety @ gharexpert, link is given below. At this link there are four- five articles relating to cracks are given which are helpful to you.
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1371
S.L.Gupta
Sat Apr 24, 2010Post  #2
priya
priya
Post subject: solution
Dear akinwumi
It depends really, every situation is different but the most likely thing is the sheer weight of the building itself causes the ground beneath it to give way and slowly but surely the building sinks into the ground. Some areas of the building sink faster than others, and when this happens it generates cracks in the mortar joints and sometimes in the brick/block themselves.
Lasting solution is its maintenance so the length and depth of all cracks should be measured. The aesthetic requirements of an individual application should be assessed and where necessary colorant may be added to the Rendacrete LW.
Fri May 07, 2010Post  #3
juhi
juhi
Post subject: yes
The cracks occur due to carelessness of contractor, mason, and ignorance of house owner and using of inferior materials in construction. If the cracks happen after all preventions, they must be repaired as soon as you observe them. Cracks threaten structural stability of the building.
These cracks are very dangerous and repaired immediately.
for further details you can read articles at www.gharexpert.com website.
and article link is:
http://www.gharexpert.com/articles/Cracks-1468/How-To-Repair-Cracks_0.aspx
http://www.gharexpert.com/category/1371/Cracks-0.aspx?CatID=1371
bye
take care..
Questions (40)
3612
Wall unit
1979
2232
ANY ONE TELL ME ABOUT THE BUILDING CRACKS
Last answer on 12/31/2020 2:31:49 AM. by S L Gupta (Civil Engg). Forum started by arun kumar sharma
1399
crack on wall plaster by gypsum
Last answer on 11/22/2016 1:25:44 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
3483
Last answer on 1/5/2022 8:16:45 PM. by Gopi Chandra. Forum started by Gopi Chandra
2488
3774
difference b/w colum, beam and RCC slab
Last answer on 7/25/2013 5:09:29 PM. by LAKWINDER. Forum started by paresh
3368
Recurring Cracks
2336
2696
How to fix cracks in my home
Last answer on 7/3/2012 12:04:18 AM. by Swati Satija. Forum started by vivek
1940
rain harvesting
Last answer on 11/18/2012 4:36:05 PM. Forum started by umesh shaha
2239
Hello Sir,I am doing one interior project of a bank but some civil part I am fac
Last answer on 1/24/2022 9:12:12 PM. by JAI PRAKASH. Forum started by Gunjan
4950
One putty mistry told that putty must be done before marble laying on floors as
Last answer on 7/4/2020 3:50:46 AM. by S L Gupta (Civil Engg). Forum started by Surinder Singh
2284
1783
How to repair the suspension crack floor
Last answer on 2/4/2015 11:31:02 AM. by S L Gupta (Civil Engg). Forum started by BAURO
2320
2117
is that crack making good treatment reliable
Last answer on 7/7/2010 8:53:52 PM. by S L Gupta (Civil Engg). Forum started by antoine vencatasawmy
3491
1953
Last answer on 5/20/2010 8:30:01 PM. by S L Gupta (Civil Engg). Forum started by sudhir
2701
283
85
29
26
32
31
30
28
28
29
25
25
22
31
22
31
31
24
How To Repair Cracks
Tips for Cement Paint
Tips for Oil Bound Distemper
Sewerage
Sewerage & Plumbing System
