Home -> Forums -> Construction -> Foundation -> door frame
door frame
Fri Apr 25, 2014Total posts : 2
Topic: door frame
My house is under construction and it will end at plint level..in few days..i want to know suitabe time for door frame..is it good to fit before roof lenter or after it..
and tell me also door frame ..which one is best stone or wood !
thank you
Fri Apr 25, 2014Post  #1
Dear Ravi
         It is good if door and window frames are fit simultaneously with brick work because doing so frame get good bonding. When we fix door frame later on, which have low bonding with side brick work. See the link below
http://www.gharexpert.com/articles/Door-Frames-993/Door-Window-Frames_0.aspx
Fri Apr 25, 2014Post  #2
Post subject: door frame ..which one is best stone or wood !
Dear Ravi, hello...! The best Material for frames of Residential Buildings is Wood...,so kindly go for wooden frames for door and windows....and kindly get it fitted simultaneously with brickwork as suggested by Respected Gupta sir... regards..
5213
2829
Can u pls send me price for upvc door and door frame.Thomas
Last answer on 7/4/2020 3:07:03 AM. Forum started by Thomas Rodrigues
2517
i want modren designs of main door frames.please sent the images to prashanthkum
Last answer on 11/18/2013 4:12:52 PM. by S L Gupta (Civil Engg). Forum started by kiranmai.a
4995
2108
Can i get the detail of Manufacture or Dealer of Aluminium Door Frame with door.
Last answer on 1/20/2021 8:26:43 AM. by jyoti. Forum started by Vijay Chikhalikar
2478
jaisalmer /sandstone use
Last answer on 9/8/2010 11:42:16 AM. by S L Gupta (Civil Engg). Forum started by geetanjali nitave
3025
What is the checklist for wooden doors?
Last answer on 3/13/2010 8:35:00 PM. by K Anjaneyulu. Forum started by vijaykumar
5277
if anybody have good main door frame models pics?,prefer rectagle model size 210
Last answer on 8/9/2013 10:15:39 AM. by GUNA. Forum started by rense
2708
1940
29057
wood calculation
Last answer on 1/5/2022 2:17:35 AM. by Navneet Jharia. Forum started by agg
5154
4057
need little calcultaion
Last answer on 7/4/2020 12:03:17 AM. by JAI PRAKASH. Forum started by gaurav
3202
3259
Door Frames
Last answer on 10/22/2010 12:50:15 PM. by Mohammed Moin. Forum started by Mohammed Moin
1721
1368
Hello, my house is 30 yrs old and all doors are made of shisham. Now we are doin
Last answer on 2/6/2017 12:02:13 PM. by S L Gupta (Civil Engg). Forum started by sachin
1876
door frame height
Last answer on 12/29/2015 12:49:44 AM. by JAI PRAKASH. Forum started by Pooja
3063
What type primer and paint should be used for concrete window and door frames?
Last answer on 6/5/2017 12:48:40 PM. by S L Gupta (Civil Engg). Forum started by vinu
2661
Pillar
2129
Curing urgent
2348
structure work
5153
Pillar foundation
2183
new house
2808
building a house
1982
Construction Agreement
3084
Foundation
2262
Foundation
1466
10031
3649
Foundation
2105
Structure proof checking
2548
Foundation design
2436
2459
Saria and cement
3637
Wall Thickness
2663
3155
13250
Steel Type
Door
Door and Window Frames
Hardwood
Hardwood door
Advantages
Teak
Teak wood frame
Which are various types of frames for Aluminium doors?
Frames for Aluminium doors-STEEL FRAME , METAL FRAME , FRAME WITH HIGHLIGHT, METAL DOOR FRAME.......
What affects the life of windows?
Mold or fungus visible on window frame.High Wind can affect door if it is not properly shut down.
