Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> doors on 4.5"partition walls
Mon May 17, 2010Total posts : 4
mohan
mohan
Topic: doors on 4.5"partition walls
Is it ok to build an 4.5" thick brick wall  (for 16x10 bedroom) as the inner wall that is of 16' in length and 10' height having a bedroom door.
Tue May 18, 2010Post  #1
priya
priya
Post subject: yes
Dear mohan,
It is ok to construct 4.5” thick brick wall. Care should be taken that wall should be constructed with cement coarse sand mortar 1:4 and it should be bonding i.e. proper jointing with the adjoining wall by proper toothing. For more details see the articles at gharexpert.com link given below.
http://www.gharexpert.com/articles/Brick-Walls,-Pillars-Structure-841/Brick-Work_0.aspx
Tue May 18, 2010Post  #2
mohan
mohan
Post subject: thankyou
Thankyou mam for your reply. I shall check with the links as well.
Wed May 19, 2010Post  #3
lalit sharma
lalit sharma
Post subject: no
 never should be thickness of  4.5" bcoz its not a strong wall it should be 6" inner wall and 9" exterior wall that's a standard to build as well as this wall will be strong .
Fri May 21, 2010Post  #4
Ramkumar G Krish
Ramkumar G Krish
Post subject: half brick wall
It is not correct, unless u dont have any roof beam. Half brick wall is not at all considered as load carrying wall. It is just acting of filler walls.
Suppose, ur building is constructed as framed structure, it is ok. otherwise dont take risk. Can u send me ur roof slab and roof beam status and location? or mail me.
3342
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1951
3936
load bearing walls
Last answer on 12/7/2020 12:04:44 AM. by mohan. Forum started by mohan
2076
outside side wall with 4.5 inch width is suggested or not ? will it cause seepag
Last answer on 7/4/2020 2:24:25 AM. by JAI PRAKASH. Forum started by ashok
2332
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
4041
Cost Comparison Between Brick Wall & Concrete Frame Structure
Last answer on 7/3/2020 11:40:50 PM. by PR Jawahar. Forum started by PR Jawahar
1288
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by Surinder Singh. Forum started by Surinder Singh
1170
1525
8110
Wall on roof slab with no beam underneath
Last answer on 9/29/2020 11:34:24 PM. by S L Gupta (Civil Engg). Forum started by Joydeep
4577
STEEL BARS IN 4.6 INCH WALL
Last answer on 12/31/2020 1:56:26 AM. by pooja. Forum started by pooja
1653
Last answer on 7/3/2015 3:57:17 AM. by JAI PRAKASH. Forum started by sandeep yadav
8820
Last answer on 7/3/2020 10:16:59 PM. by JAI PRAKASH. Forum started by sandeep yadav
1710
want to put bath space seperators to seperate the shower space whuch is 4.5 by 3
Last answer on 9/12/2011 10:13:27 AM. Forum started by NAGIR REDDY
2269
make the best use of aluminium partition
Last answer on 3/28/2012 5:11:30 PM. by Swati Satija. Forum started by sankari
3238
4939
I want design for glass partition between Drawing room and lobby.Dimensions are
Last answer on 5/12/2015 2:43:34 AM. by JAI PRAKASH. Forum started by ravneet sidhu
3287
i want living room partition idea's my room size is 10.5 x 24.7
Last answer on 8/4/2010 10:11:07 PM. by sunilrathi86. Forum started by varu
2215
how to clean sunmica doors
Last answer on 7/15/2021 12:45:52 AM. by HardissonHard. Forum started by Anu
5811
3793
9885
2670
4628
4143
2866
5008
3657
1865
2801
2610
2374
2463
2638
1808
3608
6254
Glass
Glass Partitions
Do you want natural light in your room or your house is small or you have an open floor plan. You may use glass room d..
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
Post
Post Painting Works
