For driveway in my house; Should I use Flamed granite flooring or is there any o
Fri Nov 06, 2009Total posts : 1
Sanjeev Thakur
Sanjeev Thakur
Topic: For driveway in my house; Should I use Flamed granite flooring or is there any o
For driveway in my house; Should I use Flamed granite flooring or is there any other option better than this?
Sat Nov 21, 2009Post  #1
Girish
Girish
if you are talkign about finishes.  BUSH HAMMERED finish give more anti friction factor.
If you want to be unique , consider grasscrete.
What is grasscrete ?
Occasionally confused with pre-cast blocks grasscrete is in fact a cast on site cellular reinforced concrete system with voids created by plastic void formers.
This type of construction offers significant structural advantages over precast concrete and plastic systems:
  • load bearing up to 40 tonnes gross vehicle weight
  • resists differential settlement
  • reduces sub-base depths
  • eliminates kerb edges
  • not reliant upon grass for stability
  • optimum drainage capability
Application method.
The mould is laid and the concrete is poured on site and later on the the voids are flamed to get the finish.
Challenge is the mould is made of Wax and handling the same at the climatic condition is indian hot weather is bit difficult.  if you are using the material during the december and january climate will be more easier.
flooring
Last answer on 12/16/2015 3:40:28 PM. by JAI PRAKASH. Forum started by arun
1686
what is best for driveways? Pavers or tiles or cement floor?
Last answer on 3/19/2014 5:25:49 PM. by Abhishek Garg (Builder & Engineer). Forum started by Ashok
1709
Driveway Reconcreting
Last answer on 1/23/2016 8:41:13 PM. by JAI PRAKASH. Forum started by gpeter
why we use granite for our home and kitchen ,,
Last answer on 1/30/2014 2:34:24 PM. Forum started by Nikhil rao
3597
1930
1911
flooring
Last answer on 7/28/2016 3:08:23 PM. by Aarav Sharma. Forum started by sumit
1938
Last answer on 2/18/2015 11:24:36 AM. by S L Gupta (Civil Engg). Forum started by vijendar reddy p
3325
2572
2670
2444
Underground sump finished with granite/tiles
Last answer on 12/26/2014 2:16:16 PM. Forum started by am.sridhara
3462
2379
Spiral staircase from first ground floor to first floor
Last answer on 3/4/2015 12:37:11 PM. by satish. Forum started by satish
1715
Appreciated if i could get some advice on using granite stone and the shade, sin
Last answer on 9/23/2010 11:58:18 PM. by Ar. Manoj Ralen. Forum started by cruz
2381
Front Main Gate - non iron material advice
Last answer on 8/24/2021 2:10:08 AM. Forum started by lalitha
2504
Terazzo flooring
Last answer on 2/9/2013 3:03:01 PM. by Blasio777. Forum started by Blasio777
2112
wich material using in flooring
Last answer on 10/21/2010 11:27:03 PM. by Gunjan Utraja. Forum started by Ranjit Shirke
1763
Granite
Granite Countertops
A kitchen equipped with granite countertops looks amazing and improves the beauty of kitchen and your home as well. Th..
Hard
Skylight
Types of Cement
Purchasing Guidelines for Marble and Granite Stone
Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface.
