Outdoor
earth filling under floor
Thu Sep 24, 2015
ARVIND GOYAL
Topic: earth filling under floor
Respected expert
plz guide me
as per contractor , earth has been filled in the plot about 5 feet .Afterthat he watered the underground layers by using "sabals" deep in to the soil then he watered the whole surface. When the soil dried completely he rammered the whole surface. In this way he watered and rammered the surface , not in layers
Now I want to start flooring . Is the procedure used by contractor right or it will give problems .
what should I do
plz guide
Fri Sep 25, 2015
Dear Arvind Goyal
5feet earth filling is a risky for floor. The way of flooding the filling is right.
I thing you my lay the floor of tiles or marbles etc according to your choice.
It is better to lay base coat with brick ballast and than lay cement concrete on it ( as katcha layer ) for flooring and use it for some time, than any type of depression if any than correct it and lay the final floor.
Sat Sep 26, 2015
ARVIND GOYAL
Thank u sir
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by
shaik khaja nayab rasool
1393
Last answer on 12/9/2020 11:08:46 PM. by
1794
Earth Filling
Last answer on 1/30/2014 10:54:38 AM. by
Ahmed
Ahmed
2059
Last answer on 10/15/2014 8:31:38 AM. by
naresh
2546
Earth Filling
Last answer on 12/31/2020 2:40:16 AM. by
imran
Ramrekha_vns
45464
how much cu.m of earth can excavated by machine per day
Last answer on 4/3/2021 12:46:18 AM. by
prasadtvp
sherab tenzin
1847
I m in the process of constructing a house where the structure is already comple
Last answer on 7/9/2021 4:45:04 AM. by
Karan
Sandra
3078
Stilt floor
Last answer on 7/16/2014 5:45:40 PM. by
anand
PRAKASH
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by
Girish
4443
lobar work quantity
Last answer on 2/21/2021 12:21:16 AM. by
D A VRAO
1812
I would like to construct building with Earth quake resistence
Last answer on 5/24/2013 12:11:09 PM. by
ananth
2180
pile work
Last answer on 1/27/2021 9:30:54 PM. by
SANKARDAS BANERJEE
foundatio
Last answer on 10/6/2014 1:25:17 PM. by
nitu
2430
footing
Last answer on 7/21/2012 2:08:22 PM. by
sam_m400
3202
Cracks on the walls
Last answer on 1/14/2022 10:40:04 AM. by
devjani roy kashyap
2061
treatment for white ants
Last answer on 9/20/2014 12:17:36 PM. by
richlyn
2351
Last answer on 5/22/2013 12:19:56 PM. by
Murtaza
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
2259
Using MSamd slurry for filling house foundation.
Last answer on 10/26/2015 12:05:05 PM. by
Vinod
2866
Steel calculation
Vamshidharreddy
1758
Last answer on 1/25/2022 8:44:50 PM. by
Last answer on 8/21/2021 4:42:29 AM. by
PR Jawahar
6355
Last answer on 8/21/2021 4:40:29 AM. by
shriramk1986
PR Jawahar
11377
Last answer on 6/25/2021 6:30:23 AM. by
shankar
10721
Life span of RBC lintel roof
Last answer on 2/22/2021 11:28:18 PM. by
Mohit Kumar
jaachak
2090
Foundation
Last answer on 2/9/2021 1:27:59 AM. by
Pooja
3569
R.C.C. column in Sqft
Last answer on 7/4/2020 2:03:17 AM. by
ringwang
2279
Plumbing works
Last answer on 7/3/2020 10:42:29 PM. by
manjula
1588
Last answer on 5/3/2016 11:27:23 PM. by
Test
New 4 storey building design
Last answer on 3/5/2016 10:15:22 PM. by
Raidang
1774
want a parking
Last answer on 11/22/2013 12:57:04 PM. by
vinod kumar
2404
Last answer on 2/26/2013 11:22:44 AM. Forum started by
nasad
2268
Last answer on 12/24/2011 4:12:24 PM. by
ravi at Dalmia
raj10
2565
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by
Ishmael Mphande
Patrick Salasini
2624
Last answer on 12/6/2011 7:58:37 PM. by
Manish
Manish
2501
Re-Construction
Last answer on 8/8/2010 11:31:05 PM. by
harbans singh sekhon
amit saini
3014
cracks in walls
Last answer on 5/25/2010 2:07:18 PM. by
ndevendra
Earth Filling
How does earth quake affect the building?
The outer shell of the earth called lithosphere is broken into plates which are in constant motion, moving at about th..
Which are various types of faults in electrical fitting?
These are three types of faults in electrical fitting: .Open Circuit Fault .Short Circuit Fault .Earth fault and ..
The Five Elements In Feng Shui
The Chinese recognise 5 elements which arise out of the interplay of yin and yang. Ideally there should be a balance o..
