| Earthquake Resistant Building Construction Earthquakes strike without much warning. It may harm badly designed & constructed buildings killing its inhabitants. T.. |
Make your home earthquake proof The following points should be kept in mind during construction of building for the protection against ‘Earth Quake’.
| Which type of building materials and construction practices are recommended for protection against earthquake? RCC : It is defined as reinforced cement concrete.
Steel: It is an metal alloy of iron with small amounts of carbon;.. |
| What is recommended size and shape of building for the protection in earthquake prone areas? All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s.. |
| Earthquake safety tips Earthquake can strike suddenly with very little warning. One minute you may be enjoying the company of your kids and f.. |
Cupola Proportions Tips for cupola proportions |
| Guidelines for Ventilation in Building Proper ventilation in building ensures sound health and good living conditions. This write-up tells you some tips for .. |
