Home -> Forums -> Construction -> Ground work -> electric&wiring
electric&wiring
Sat Oct 11, 2014Total posts : 1
sunil kumar
sunil kumar
Topic: electric&wiring
can anyone suggest electric & wiring drawing for my duplex? House plan is attache
Attachments: plans.zip on Sat Oct 11, 2014,&n
Thu Oct 16, 2014Post  #1
Please consult with an electrical engineer with your requirements in each room.
2722
electrical
Last answer on 7/3/2020 9:50:06 PM. by JAI PRAKASH. Forum started by sunil kumar
3086
2430
Electic wires
Last answer on 1/17/2014 12:15:51 PM. by S L Gupta (Civil Engg). Forum started by rajesh
1820
After collecting the electric bil.Then how to keep these electric bills....
Last answer on 2/8/2013 2:28:38 PM. by S L Gupta (Civil Engg). Forum started by Purushotham Reddy
2507
2962
1992
cables
Last answer on 7/3/2020 10:07:56 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2275
electric fitting
Last answer on 12/9/2020 5:31:07 AM. by SANJAY DUSANE. Forum started by dspatwal
1922
chick door
1994
Mini Excavator, Small Body with Big Power
Last answer on 1/4/2022 11:01:08 PM. by S L Gupta (Civil Engg). Forum started by SanyIndia
2007
Consultant
Last answer on 5/18/2010 2:42:29 PM. by . Forum started by srinivas reddy
2079
wiring
Last answer on 5/19/2015 9:10:27 PM. by JAI PRAKASH. Forum started by ananth
2004
wiring
Last answer on 5/19/2015 9:10:22 PM. by JAI PRAKASH. Forum started by ananth
1567
wiring run above ceiling
Last answer on 6/20/2016 12:13:42 PM. by SW Psychology. Forum started by krish
18382
2022
3238
2466
1938
Is it necessary to put iron wire under tiles at enterance of all doors in house?
Last answer on 9/18/2013 3:11:29 PM. by S L Gupta (Civil Engg). Forum started by bakula
2995
8158
software
3899
2730
1833
lanterns
3133
false ceiling
2245
about construction
1786
4153
Cement Coba
3076
Water Harvesting System
1676
1757
water tank
2058
1760
1634
Pool construction cost
1993
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
Electric
Electric Shock Proof Home
Electrical
What is binding wire
Energy
Energy Saving Tips
Saving energy will definitely help you minimize your energy/electricity bills. Here are some nice tips to save energy;..
Electric
Electric
Electric
Electric Fitting and Lighting Fixtures
Electric fitting must be safe and ensure proper safety to the occupants of the house. Low quality products or applianc..
