Home -> Forums -> Construction -> Start Construction -> electrical
electrical
Tue May 09, 2017Total posts : 1
simran
simran
Topic: electrical
where are the m.c.b board located in flats
1) All m.c.b boards in ground F.L of each flat or
2) M.C.B board applied particular flat
also want to know about meter board
Thu May 11, 2017Post  #1
Dear Simarn,
          It is better to fix mcb at all floor level for easy functioning.
2348
11692
2550
Factory Main Door
2568
cost of electrical
1972
Elctrical wiring
3753
1908
1960
2022
2962
2593
JOINERY WORKS
2466
1525
2337
electrical installation
Last answer on 11/27/2021 2:32:14 AM. by Navneet Jharia. Forum started by brajesh pandey
2275
Ac and Electrcial
1922
electrical work in house
Last answer on 9/4/2021 6:00:39 AM. by JAI PRAKASH. Forum started by milind
2850
1721
Request for electrical and Plumbing Materilas list
Last answer on 10/10/2014 12:52:53 AM. by JAI PRAKASH. Forum started by endayveed
1768
Electrical Conduits
Last answer on 5/9/2014 7:35:42 AM. by ajaywahi. Forum started by ajaywahi
2256
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
3310
2312
Electric
Electric
Electrical
Electric
Electric Shock Proof Home
Earthing
Switches
