electrical installation
Sat Nov 30, 2013Total posts : 1
brajesh pandey
brajesh pandey
Topic: electrical installation
For residential building - how to estimate wiring and electrical fitting ?. which product should i use for electrical fitting ?.
what is specification for wiring and electrical fitting?
Sun Dec 01, 2013Post  #1
Post subject: estimate wiring and electrical fitting
Hello..! Brajesh, For residential buildings ,The Electrification plan of Each floor is the first requirement to Estimate the quantity and cost of Wiring , fittings and fixture. There are so many brand of electrical product available in market but All the products used for Electrification should be of ISI standards....regards
Elctrical wiring
2367
how is installation of glass curtain done, details
Last answer on 6/10/2016 12:48:02 PM. Forum started by neetaa gupta
2164
Last answer on 7/4/2020 2:33:32 AM. by S L Gupta (Civil Engg). Forum started by Monish Salhotra
3753
1908
2348
2568
cost of electrical
2550
Factory Main Door
11692
2027
2022
2962
1922
electrical work in house
Last answer on 9/4/2021 6:00:39 AM. by JAI PRAKASH. Forum started by milind
2466
2593
JOINERY WORKS
2275
Ac and Electrcial
1525
1960
2315
Hardwood Flooring and its Installation
Last answer on 11/18/2009 2:06:31 PM. by deodipnsingh. Forum started by suren
15
17
Electrical
Electric
Electric
Hardwood
Hardwood flooring is one of the expensive yet elegent flooring option. Its installation is not that typical but still ..
Electric
Electric Shock Proof Home
Cupola installation tips
Tips for cupola installation
Vinyl
Vinyl Flooring
