Ground work
electrical work in house
Wed May 20, 2015
milind
Topic: electrical work in house
I have started house construction in Nagpur. Pl let me know -
1) How electrical contractors charge for wiring (per feet or no of electrical points) when material will be provided by owner
2) What precautions are to taken while finalizing electrical contract and what are hidden cost involved in it ?
Thanks in advance
Wed May 20, 2015
There is no hidden cost if you are providing the material, The contract can be per point or the /sq.ft. area of your roof with unlimited point under it. The rate are different for only wiring, with switches and with Fan and lights installation. It starts from Rs. 10/Sq.ft. in case of area of at least 1000 sq.ft.
2593
JOINERY WORKS
Last answer on 12/11/2013 11:18:00 AM. by
Last answer on 8/8/2016 2:21:56 PM. by
Balu Menon
2015
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Last answer on 5/5/2014 2:31:18 PM. by
PR Jawahar
Anurag
2022
Last answer on 12/4/2014 1:13:26 AM. by
Last answer on 7/6/2021 5:06:36 AM. by
Last answer on 10/3/2017 7:03:56 AM. by
gautam kumar
gautam kumar
1965
electrical and plumbing work
Last answer on 12/11/2013 11:20:51 AM. by
neelam rathi
3686
cost of plumbing,sanitaion,electrical as %of civil work
Last answer on 11/16/2021 12:22:16 PM. by
muralibgowda
naina
2347
Last answer on 11/17/2021 5:09:01 AM. by
ramesh joshy
11692
Last answer on 2/2/2022 12:01:14 AM. by
meenakshisundaram
2550
Factory Main Door
Last answer on 11/30/2021 11:44:17 PM. by
c k Ramaprasad
2567
cost of electrical
Last answer on 12/10/2013 11:32:52 AM. by
neelam rathi
1971
Elctrical wiring
Last answer on 3/5/2016 9:12:57 PM. by
kumarakrishnan
1906
Last answer on 11/19/2020 4:21:26 AM. by
Sanzana Hosen
3752
Last answer on 1/30/2017 12:00:36 PM. by
3397
Bathroom Cleaning Tips
Last answer on 6/10/2019 1:04:58 AM. by
jaswinder Singh
Nitesh Patel
2012
FOR STREET HOUSES VASTHU WILL WORK....OR NOT AT ALLWORK.......?HOW TO FIND THE M
Last answer on 3/25/2011 1:03:39 AM. by
D.Ramachandran
1820
Last answer on 7/3/2020 11:35:37 PM. by
Ganpat B Chaudhary
2075
Need suggestions for removing the cracks ( images attached )
Last answer on 4/12/2014 12:54:49 PM. by
viju
viju
2995
Karan
8159
software
Vaasku
sco4666
sagar suryawanshi
2730
Manish Singh
1833
lanterns
ARVIND GOYAL
3133
false ceiling
sabita laskar
2245
about construction
simran
1786
lowz
4153
Cement Coba
Last answer on 12/21/2021 8:15:49 AM. by
Prasenjit
3076
Water Harvesting System
sunny420
1676
Robert
1758
water tank
rodmotall4
sadanand
2058
sumit
1760
jitendra kumar
1634
Pool construction cost
Erling
Shardul
1993
sanyindias
2738
Regarding roof beam
Amit Kumar
Fire Stair case
mvxmanazxmfsm
tejas
2645
MOHD WAKEEL
2371
super structure
anil kumar
Electric Shock Proof Home
10 things to check before the rain hit your home!
Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr..
