what is epoxy floor coating? please explain me.
Sat Jan 26, 2013Total posts : 2
RRSAMY
RRSAMY
Topic: what is epoxy floor coating? please explain me.
Sat Jan 26, 2013Post  #1
GUNA
GUNA
HI RRSAMY,
Definition of Epoxy Flooring
Epoxy flooring may not be something that you’ve heard of before but in its simplest definition, it is a flooring surface that is made up of multiple layers of epoxy that is applied to the floor to a depth of at least two millimeters   The difference between an epoxy floor and an epoxy floor coating lies in the depth of the epoxy. As stated, an epoxy floor must be at least two millimeters thick.  Any epoxy floor that is less than two millimeters thick is best referred to as an epoxy floor coating.
You might also be wondering exactly what epoxy is.  Epoxy in this case refers to a system that is made up of two main components – resins and hardeners.  The resin and hardener is mixed together where they chemically react to form a rigid plastic material that is strong, resistant to degradation and that bonds extremely well to its substrate.  Epoxy floors are so strong that they can be used in even the most demanding of industrial environments.
And there are many types of flooring depends on the usage
Fri Feb 08, 2013Post  #2
Jemimmarichardson
Jemimmarichardson
Post subject: Epoxy floor coating
Hello friend,
Epoxy paint is a finish material used in homes and commercial buildings. Like all epoxy products, it is a two-part system, composed of both a resin and a hardener, with color added to provide the desired finish. It is used primarily as a floor covering, and forms a hard, shiny surface upon application.
1428
Epoxy painting for floors
Last answer on 4/4/2015 12:02:08 PM. by S L Gupta (Civil Engg). Forum started by Akshay Wadke
2439
False Ceiling
Last answer on 9/1/2015 2:55:46 AM. by JAI PRAKASH. Forum started by Vijay
1125
Is Fusion-Based Epoxy coating a practical means to prevent corrosion in TMT ste
Last answer on 1/10/2019 12:19:14 AM. Forum started by Anu Mohan
4335
i am really interested in these floating stairs, can some body explain to me how
Last answer on 12/31/2020 2:40:31 AM. by ardes_architects. Forum started by alex polley
1965
WILL PLEASE EXPLAIN GARJAN WOOD CAN IT BE USED FOR INSIDE WOODEN WORK.
Last answer on 10/20/2011 1:57:49 PM. by ajaykapoor. Forum started by ajaykapoor
2971
The Almirah with money or cupboard to placed in which direction . Which part of
Last answer on 11/14/2019 11:39:44 PM. by Nageshwar. Forum started by Parthasarathy
6306
terrace flooring
Last answer on 7/3/2020 10:25:00 PM. by JAI PRAKASH. Forum started by Radhika
2014
space parameter for sanitary fittings
Last answer on 1/23/2016 8:28:13 PM. by JAI PRAKASH. Forum started by sandeep yadav
4925
LOAD BEARING STRUCTURE
2936
Right price or not .. Kindly advise
Last answer on 7/3/2020 9:28:23 PM. by S L Gupta (Civil Engg). Forum started by everfor
1304
what is epoxy floring. what is the methodology to do it. Explain please.
Last answer on 10/30/2010 9:50:28 PM. by S L Gupta (Civil Engg). Forum started by vijay
2214
Do you have paint reps in the USAaround the northwest Indiana area.I have a cust
Last answer on 11/16/2012 8:35:46 PM. Forum started by Jackie Martin
15490
apex ultima vs weather coat? please help me choosing the right exterior paint. a
Last answer on 12/6/2012 11:46:26 AM. by S L Gupta (Civil Engg). Forum started by rajarshi ray
2992
Wall Putty ,primer and paint
2084
CEMENT PANI - Plaster Works
3069
Painting
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by S L Gupta (Civil Engg). Forum started by Arun
2510
Pile Foundation
15
17
Epoxy
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
Which types of finishing/ protective coating materials are recommended for Aluminium doors?
Finishing/Protective materials for Aluminum Doors-Primer, Raw linseed oil, Turpentine, Exterior Grade enamel paint......
Tips for Oil Bound Distemper
Terrazzo
What is the raw material recommended for painting of metal surface?
Red oxide zinc chromate primer shall be used for iron and steel work including galvanized steel.Zinc chromate primer s..
Refinishing Hardwood Floors
Tips for Cement Paint
Textured
Textured Paint
Textured paint creates stunning effects on the walls of your house. It not only makes inspiring textures but also prov..
