Home -> Forums -> Construction -> Start Construction -> estimate for 3 storey building in pune
Fri Jul 19, 2013Total posts : 4
ksp
ksp
Topic: estimate for 3 storey building in pune
I wish to know approx estimate for 3 storey building in pune measuring 16.5*45 feetin plot measuring26.5*70. Also demolition cost esting stucture with comman wal which is not to be touched ?
Fri Jul 19, 2013Post  #1
Dear ksp
The cost of construction is based on the plan ,elevation and specification used in the construction of building.  cost is also co related with types of foundation,earth quack measure. For accurate costing you can e-mail at support@gharexpert.com for detail estimate.See the link below.
Mon Jul 22, 2013Post  #2
ksp
ksp
Post subject: thanks
Thanks a lot sir for estimator. However I didnt find alumnium sliding windows in it. also there are no details for verious vitrified tiles like anti skid, sizes 24x24,16x16,etc. My contractor is stating the rate at Rs.1050 to1100 per sq feet. It excluding demolition cost of standing stucture of 600sq feet which is 20 years old and bulit in load bearing stucture. demolition cost is stated by an other contractor is Rs.50000. My question is 1) Are these cost viable? 2) how much material from demolition stucture can be reused as buliding contractor said he will be using steel from old slab at plith level to strenghthen foundation?
Mon Jul 22, 2013Post  #3
ksp
ksp
Sir please find the rough sketch made in Excel for new building.
Attachments: PLAN.xls Mon Jul 22, 2013,&n
Mon Mar 16, 2020Post  #4
          Thanks for visiting the site.
2007
804
1652
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
1973
Elctrical wiring
1727
Want to construct commercial building in 3200sqft land.
Last answer on 10/8/2013 3:46:26 PM. by S L Gupta (Civil Engg). Forum started by sudheer
2165
want to built double storey in foundation of 2ft.abv. gnd.level,is it possible?
Last answer on 10/19/2012 12:02:07 PM. by S L Gupta (Civil Engg). Forum started by ashish
2253
3369
2255
Sreel pillars(post)
4651
3795
Need Construction cost of G+1 house in Pimpri chichwad pune..
Last answer on 6/20/2016 1:18:28 PM. Forum started by rakesh
56
Top Islamic Astrologers in Pune 91-7681982445
Last answer on 7/5/2024 1:45:18 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 1:45:19 AM. Forum started by Miyan Akram JI
54
Last answer on 7/5/2024 1:45:20 AM. Forum started by Miyan Akram JI
63
56
Last answer on 7/5/2024 1:45:21 AM. Forum started by Miyan Akram JI
55
Last answer on 7/5/2024 1:45:22 AM. Forum started by Miyan Akram JI
3312
2236
2312
2061
Orientation
Orientation of Building
Cupola Proportions
Tips for cupola proportions
Fire
How to Design a Garage
Comparison
