Home -> Forums -> Construction -> Start Construction -> estimate cost for 1800sfft building construction
Tue Mar 04, 2014Total posts : 1
Satyanarayana Seeram
Topic: estimate cost for 1800sfft building construction
I have a 1800sqft land. i am planning to construct a house in that.
In the ground floor i want to leave it for parking and shop.
first floor : 2 individual houses 2bhk (in one i want to stay and other for rent)
second floor : 3 individual house 1bhk for rent
can you please point me to the plan and estimate cost for this.
Thanking you,
Satya.
Wed Mar 05, 2014Post  #1
Dear Seeram
See link below
6099
What is construction cost
2022
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 7/4/2020 3:43:22 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
6254
2471
please send the measurements so that iam grateful to you...and estimated cost bu
Last answer on 5/16/2012 10:44:00 PM. by Gunjan Utraja. Forum started by spmurmu
2402
what is the cost estimated to fullfil .
Last answer on 6/29/2012 8:16:15 PM. by Gunjan Utraja. Forum started by naresh khari
2858
modular kitchen
Last answer on 2/23/2022 4:38:18 PM. by JAI PRAKASH. Forum started by Anu
1971
Elctrical wiring
2267
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
2974
2121
2557
2882
3802
22 x 63 size plot construction.
Last answer on 7/16/2015 10:39:22 PM. by JAI PRAKASH. Forum started by rajkumar pola
3346
Sample layout for building flats on my plot, and rough cost estimate
Last answer on 10/21/2012 11:03:49 PM. Forum started by solemnamritanshu
2048
estimated cost of additional room construction on 1st floor terrace
Last answer on 1/25/2014 11:49:44 AM. by S L Gupta (Civil Engg). Forum started by sujal
1556
I want to get estimated cost for 720 SFT plot with basic construction material
Last answer on 9/6/2015 10:56:00 AM. by JAI PRAKASH. Forum started by indrajit
1644
Construction Cost Estimate
Last answer on 5/3/2016 12:17:22 AM. by JAI PRAKASH. Forum started by Nazir Khan
3310
2133
2059
Earthquake
Comparison
How to Design a Garage
Orientation
Orientation of Building
