Home -> Forums -> Construction -> Start Construction -> extend horizontally side wall for upper floor
Fri Oct 10, 2014Total posts : 6
navneet
navneet
Topic: extend horizontally side wall for upper floor
sir , I want to shift upper floor's wall horizontal as given sketch
please suggest how to do this
Attachments: extend floor.png on Fri Oct 10, 2014,&n
Sat Oct 11, 2014Post  #1
navneet
navneet
Post subject: extend horizontally side wall for upper floor
 frame structure building and extend 30 inches at left side wall of building please suggest me
Mon Oct 13, 2014Post  #2
navneet
navneet
viewed 67 .........but no suggestion/opinion??????
Mon Oct 13, 2014Post  #3
Unoara Design Hub
Unoara Design Hub
Dear Navneet,
Assuming you are planning to construct a room with a roof and this extension will bear the load of these structural members,you can still extend the upper floor slab by 30" by:
1) either erecting external columns/pillars - concrete/metal to allow the upper load to get distributed below.
2) OR use structural cantilever design for this 30" but then the upper members need to be light weight and the Ground Floor Ceiling(Slab) beam needs to have the strength to take up this additional shear load.
These are options but we STRONGLY advise not to go on your own but to consult an Architect or Structural engineer before commencing to get a complete analysis and site recede done to ensure safety of the building and its occupants.
All the best.
UNOARA DESIGN HUB
Bangalore
Sat Oct 25, 2014Post  #4
navneet
navneet
Thank you UNOARA DESIGN HUB for your suggestion
I want to use
structural cantilever design without demolition existing frame structure is this possible? please give detailed information thanks in advance
I attached sketch with plan
Attachments: 1.png Sat Oct 25, 2014,&n
Mon Oct 27, 2014Post  #5
navneet
navneet
620 +  members have seen , but no response, except  UNOARA DESIGN HUB
I had not extended the roof slab or any beams as cantilevers earlier to make the balconies and one side (which is open place) for the proposed upper floor as given sketch
Request to all senior member (Engineers) please suggest .................
Mon Oct 27, 2014Post  #6
Dear Navneet
       It is better if you consult any structural engineer, who can visit the site and give design after seeing all aspects already constructed.
3763
My plot is south east extended,extended in east with two side road in east
Last answer on 10/18/2016 5:22:59 PM. by priya. Forum started by A K Sah
2257
may i know the lower portion and upper portio of the wall color
Last answer on 3/14/2010 7:25:28 AM. by Ajit Tareeka. Forum started by MARIBEL
2063
Sir, I am to build a basement leaving 2 meters each from both of side buildings.
Last answer on 9/15/2012 6:49:42 AM. by piyush. Forum started by Satish bajaj
2241
i have purchsed daigonocaly plot for residential purpose there is south corner i
Last answer on 12/6/2010 1:50:39 PM. by S L Gupta (Civil Engg). Forum started by bipin brahmbhatt
1868
Leakages in Apartment
Last answer on 12/12/2015 12:58:49 AM. by JAI PRAKASH. Forum started by nitin_patel
1748
2889
Pillar distance and steel rod dia
Last answer on 8/1/2014 7:37:46 PM. Forum started by SAROJINI
1624
If my bedroom(FF) is slant in one side (SW), can i make my wardrobe that side so
Last answer on 10/25/2014 8:51:43 PM. by JAI PRAKASH. Forum started by SAROJINI
6065
Help required: House plan for 33 x 50 Sq ft North facing plot
Last answer on 7/2/2020 10:07:28 PM. by S L Gupta (Civil Engg). Forum started by sheeja
2525
2437
Need Help internal walls cracking horizontally, diagonally and vertically
Last answer on 7/14/2014 2:25:04 PM. by S L Gupta (Civil Engg). Forum started by Srinivas
3117
what colour use bedroom east and south side wall
Last answer on 11/3/2019 11:36:47 PM. by S L Gupta (Civil Engg). Forum started by P.T.PONRAJ
1070
building 8" wall onthe slab will effecet the on the outer side
Last answer on 7/4/2020 2:02:31 AM. Forum started by Badhavath Rajeshwar
1531
if west side set back is more in the house and north side house wall is not havi
Last answer on 12/12/2017 2:33:18 AM. by S L Gupta (Civil Engg). Forum started by Geetha Kachala
3574
2150
Map for Gaumukhi Plot
Last answer on 7/4/2020 2:28:56 AM. Forum started by akshay
2652
map for gaumukhi plot
Last answer on 7/4/2020 2:28:35 AM. Forum started by akshay
1037
I had constructed 4" wall on the exterior side on the first floor with 2" plast
Last answer on 7/3/2020 11:37:23 PM. by Badhavath Rajeshwar. Forum started by Badhavath Rajeshwar
1287
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by Surinder Singh. Forum started by Surinder Singh
3310
Comparison
Canvas
Canvas Wall Art
Wall
Wall Decor
What are various designs available in side hung doors?
Designs available in Side Hung Doors.....
Paint
Wall
Wall Accents for Your Rooms
