extending existing terrace
Wed Aug 20, 2014
ADINATH
Topic: extending existing terrace
dear members...can someone please tell me..if it is possible to join a new terrace 'flush' with an already existing terrace...and if yes ..then how to go about it..?
Thu Aug 21, 2014
Dear Adinath
It is possible to join new terrace with old at same level. Treat the joint as like EXPANSION JOINT.
Thu Aug 21, 2014
ADINATH
thank u for replying to my post sir...I have another question regarding terrace sir...which is...what is the mnimum thickess for a sloping terrace roof ?
Fri Aug 22, 2014
Dear Nath
The minimum thickness of sloping roof is 4''.
Sat Aug 23, 2014
Post #4
ADINATH
thank you sir!
3122
Last answer on 8/27/2015 6:46:22 PM. by
5171
Last answer on 12/22/2009 4:23:49 PM. by
Praveen
amarchatterjee
3763
My plot is south east extended,extended in east with two side road in east
Last answer on 10/18/2016 5:22:59 PM. by
priya
A K Sah
2483
Extending the existing cantilever
Last answer on 3/30/2017 12:58:03 PM. by
Abhi
2526
Last answer on 5/16/2021 2:27:15 PM. by
bhaskar
2126
can we extend south-west corner ?
Last answer on 2/22/2011 11:52:03 PM. Forum started by
ashvin
2897
Terrace water proofing
Last answer on 7/13/2020 12:26:53 AM. by
ravi pachipala
3757
PLEASE TELL ME THE DIFFRENCE BETWEEN B.B.COBA AND IPS TYPE OF WATERPROOFING FOR
Last answer on 7/30/2014 9:22:58 PM. by
2298
Last answer on 9/29/2014 12:34:55 PM. by
Sanjay Gupta
1544
Last answer on 1/28/2018 4:51:24 AM. by
Er.S.K.Jain
S.Nagarajan
1800
Last answer on 7/4/2020 2:32:26 AM. Forum started by
shivam gupta
2639
where to keep pooja mandir in living room measuring 17X19sq feet with terrace in
Last answer on 3/24/2012 2:53:23 PM. Forum started by
srpatil
2303
Last answer on 5/17/2019 12:11:39 AM. by
Er.S.K.Jain
2957
Need help for terrace room to cover iron bars (Picture Attached)
Last answer on 12/28/2012 11:27:53 AM. by
prabhjeet
9310
MY HOUSE IS NORTH FACING.IT IS ALSO L SHAPED,EXTENDING SOUTH WEST.AS PER VASTU W
Last answer on 8/23/2012 4:53:22 PM. by
Ravi
mahender
2694
MY HOUSE IS IN NORTH DIRECTION.IT ALSO EXTENDS IN SOUTH WEST DIRECTION.WHERE SHO
Last answer on 8/24/2012 1:56:34 PM. by
mahender
13772
overlap length to steel
Last answer on 6/16/2015 4:11:51 AM. by
shaik khaja nayab rasool
2833
As per Vastu, Can we make building with North-West corner extended with other pa
Last answer on 6/8/2012 9:37:13 PM. by
Maanoj
M.J.Khan
1843
Can we extend the outside part in south-west corner ?
Last answer on 2/23/2011 12:03:37 AM. by
ashvin
Roof Garden
