Home -> Forums -> Construction -> Start Construction -> filler slab roofing
filler slab roofing
Sat Mar 06, 2010Total posts : 1
narendra
narendra
Topic: filler slab roofing
Hi ,
I am making a house in kerala would like to know more about filler roof slab .Do you know any contractor making roof by this techniques in tellichery in kerala.
Mon Mar 08, 2010Post  #1
Post subject: Reply- fillar slab
Dear Narendra,
Great to know that you are building a new house. Here is a link of post on fillar slab to help you to know more :
http://www.gharexpert.com/a/ashishbatra/1670/Filler-Slabs_0.aspx
2096
9917
3768
1917
3987
Roof leakage
6626
Last answer on 1/7/2022 1:25:49 AM. by Girish. Forum started by Girish
2809
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya
191948
5701
3974
cost estimater
1769
1510
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
1076
4954
2020
5224
3093
42619
Labour Cost for Roof RCC work
1882
2482
3308
3321
4450
4026
2249
2725
4235
5209
2396
2322
2025
2463
2142
3216
2075
12547
2190
2031
2752
Cooper
Asphalt
Asphalt Shingles Roofing
