The flooring of my home is marble and i would like to insert brass patti in the
Mon Jun 08, 2009Total posts : 2
mohit
mohit
Topic: The flooring of my home is marble and i would like to insert brass patti in the
The flooring of my home is marble and i would like to insert brass patti in the marble but i am worried about it being losing its lustre and turning black in a couple of years.when should brass inlay be done? Is their a problem in installing before the polishing of floor or should it be done afterwards?
Mon Jun 08, 2009Post  #1
Post subject: Why do you want to insert brass patti in marble ...
Why do you want to insert brass patti in marble tiles? Is there any specific reason behind it? Is it a new trend?
Mon Jun 08, 2009Post  #2
Anjleen
Anjleen
Post subject: Brass in Marble Floor
It is better if you install brass before polishing, so that grinding of floor is made for whole the flooring as one unit and after final grinding polishing work is to be done.
2281
which marble and its sub category to buy
Last answer on 7/3/2020 11:36:27 PM. by JAI PRAKASH. Forum started by sushantsah
2317
Hi my Name is Riyaj khan i am Marble flooring liver incharge for indian Marble,
Last answer on 7/3/2020 11:34:52 PM. by JAI PRAKASH. Forum started by RIYAJ KHAN
404
flooring
Last answer on 12/18/2010 12:30:53 PM. by S L Gupta (Civil Engg). Forum started by ali
1597
How much Marole required
3113
Marble Flooring for flat
Last answer on 7/3/2020 11:32:44 PM. by Gunjan Utraja. Forum started by pumping iron
2972
duration of constucting home
2569
2300
marble flooring is done and pop work is over can i start birla putti before marb
Last answer on 7/3/2020 11:35:07 PM. by JAI PRAKASH. Forum started by ashok
3351
3807
2544
price for brass door and what is the size
Last answer on 7/3/2020 11:36:39 PM. by jyoti. Forum started by amin
1771
1612
flooring white marble in 700sq ft areaestimate plz9718739994
Last answer on 10/4/2016 9:21:30 PM. Forum started by Kamrul
1821
1669
Cement requirement
2266
plz suggest me directions were to keep white marble tortoise in workplace and in
Last answer on 3/4/2012 6:03:32 PM. Forum started by nikita jain
2423
I am constructing first floor now. I want to know which flooring is better. Whet
Last answer on 4/17/2011 7:42:19 PM. by S L Gupta (Civil Engg). Forum started by S.BHUPAL RAJU
2249
which flooring is suitable - marble or marbonite for heavy traffic area ?
Last answer on 2/5/2011 7:06:44 PM. by Nikita. Forum started by vikram khot
Brass
Brass Doors
Brass doors are very popular for Georgian and Victorian types of architecture in ancient buildings. Today brass doors ..
Advantages
Italian
Italian Marble Flooring
Specifications
Terrazzo
MARBLE STONE
Marble shall be hard ,sound , dence, and homogeneous in nature with crystal in texture as far as possible.
White
White Marble
Nowadays marble become to be a favorite material for kitchen countertops, sink tops, floors, and wall tiles. White ma..
