Home -> Forums -> Construction -> Bricks -> fly ash bricks
fly ash bricks
Sun Aug 26, 2012Total posts : 2
santhosh
santhosh
Topic: fly ash bricks
i want to construct a house using fly ash bricks.
what is the cost of a fly ash brick in Bangalore,
the sizes in which it is available
and also the dealers in Bangalore.
Mon Aug 27, 2012Post  #1
Dear Santhosh
              You may contact the building materials dealer in bangalore for fly ash bricks.
Wed May 25, 2016Post  #2
Dear Krenap
     Thanks for information.
2931
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by Kranap. Forum started by mamta
2708
type of brick
1941
Availibility of Fly ash Bricks near Kolkata dumdum airport
Last answer on 2/11/2013 3:12:32 PM. by akmurty1. Forum started by DK
2405
3967
use of fly ash brick
Last answer on 10/18/2011 3:51:59 PM. by S L Gupta (Civil Engg). Forum started by amit
1785
3606
2658
1635
sir i have recently consstructed a house using fly ash based cement for ground f
Last answer on 7/28/2015 11:25:48 PM. by JAI PRAKASH. Forum started by baheer din
2047
question
Last answer on 4/15/2013 12:34:12 PM. by S L Gupta (Civil Engg). Forum started by arpitbedi
2457
estimate
2560
New House Plan and Construction
Last answer on 7/4/2020 4:23:20 AM. by Shanthakumar. Forum started by Vaishnavi
4372
Ready Mix Concrete
2992
2018
4179
GLASS BLOCKS / BRICKS
4056
2350
2874
FLYASH OR CLAY BRICK
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2821
2350
3172
bricks
5659
2014
3238
5135
Use of Solid Concrete Bricks
1624
1341
1846
1480
1797
2230
1723
FLY ASH BRICKS
FLY ASH BRICKS
CONCRETE
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
