Home -> Forums -> Construction -> Start Construction -> foam concrete
foam concrete
Sat Sep 10, 2016Total posts : 2
arun chaudhary
arun chaudhary
Topic: foam concrete
i wish to build my banglow. I am confused whether
to use foam concrete or conventional concrete. Pl.
let me know comparison between these two,
& advise which to use.
Sat Sep 10, 2016Post  #1
bhuvaneshwaran bn
bhuvaneshwaran bn
Hello Arun.
Foam concrete is Light weight ,it will reduce over all Weight of the Building Structure.
Ask for Lab testing report the Product and chk for the Fire Resistance,durability in Beams/columns,Environment Study also (since Plastic is used)
then u can Compare the conventional Concrete interms of Above reports.
Cost-wise always Conventional is cheaper because of availability.
Bhuvan
hpspacedesignbuild@gmail.com
Sat Sep 10, 2016Post  #2
arun chaudhary
arun chaudhary
Thanking you M. Bhuvan,
what is the best technic for rapid and strong construction as well as economical.
Arun. ,
2808
1061
I would love someone suggesting on how to make cushions for wooden sofas? I mean
Last answer on 10/27/2010 5:26:17 PM. by S L Gupta (Civil Engg). Forum started by swopnna reddy
1747
1443
3463
Cost of concrete walls
3417
3260
2012
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by S L Gupta (Civil Engg). Forum started by kanwer sajjad
2216
sand alternate for concrete
3750
3744
concrete mix design software
2267
2398
roof concrete
2396
1972
1609
2211
zero slump concrete
1771
20052
2451
3273
3283
4429
3974
2196
2699
4210
5167
2378
2294
1995
2447
2114
3193
2046
12514
2163
2010
2726
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
