Home -> Forums -> Interior -> Home Improvement -> foundation details for termite proofing
Wed Apr 06, 2016Total posts : 1
zakia sultana
zakia sultana
Topic: foundation details for termite proofing
Wed Apr 06, 2016Post  #1
Dear Sulthana
Pre-construction chemical treatment
Termite treatment called “pre-construction chemical treatment” must be done at the time of construction. To treat the soil under foundation with soil insecticides is the most common method of termite treatment. A chemical barrier is made between ground and masonry of the foundation to prevent termites’ approach to the building. Anti-termite chemical treatment can be done in following way.
  • Treat bottom and sides of excavated portions of all walls with chemical before starting construction work in foundation.
  • Also treat floors of the rooms by making holes in the earth under floors and filling them with chemicals.
  • Make use of chemicals at the junction of walls and floors.
  • Treat external perimeters of the building by making 300 mm deep holes filled with chemicals to provide a barrier around building or the house.
  • Make holes into the earth and fill them with chemicals to treat the soil under plinth protection and around pipe.
  • Treat expansion of joints at ground level with anti termite chemical treatment.
  • Use anti termite chemical to treat ‘chowkhats’ or door frames before fixing them into the building.
Precautionary measures
When termite treatment is not done at the time of construction, the following precautionary measures should be taken for prevention of termites in the building.
1. Keep drains and gutters clean to avoid leakage
Water supply pipes and sewerage pipes should be kept clean to avoid leakage causing dampness. The gutters and drains should be cleaned to avoid leakage in their pipes. Pay particular attention to the pipeline which leads to kitchen and bathroom. Keep kitchen and bathroom area clean and ensure if there is any leakage in external and underground pipe fittings. Also make sure that there is no leakage in roof of the building/house.
2. Remove sources of moisture
The courtyard or crawl space should not be moist or damp for long time as termites are attracted towards moist soil and need water to live. Do not let the water flow towards the foundation of building. Keep rain water and other sources of waste water away from foundation of the building and construct plinth protection around the house/ building.
3. Destroy colonies of termites
Destroy nests or colonies of termites under the ground, in the soil near ground level in a stump or at other places of timber in a conical or dome shape mounds where subterranean or ground termites live and cause most of the damage in buildings.
4. Remove wood products
Eliminate wood products like cardboard, paper and other wooden products which are sources of termite food in damp state. Do not fix wooden part of fences, wooden stairs, and wooden bottom members of stairs without doing anti termite treatment.
5. Terminate wood and soil contact
Remove all wooden piles, stumps, yard debris and garbage etc. around your home.  Do not stack/ store any type of wood inside or near your house or on the ground in garage as these places are easy to access by termites. Do not bury any piece of timber like stumps of trees etc. in or near home. They should be excavated during construction of foundation. Wooden articles such as plank shelves at least 18” should be kept above ground.
6. Keep foundation free from mud shelter and patch up cracks
Also keep unprotected portion of the foundation free from mud shelter tubes to avoid termite protection.  Patch up cracks and cavities in masonry with cement mortar as termites can enter the building through them.
7. Fill junctions of walls and chamber properly
Properly fill junctions of walls and chamber at the time of flooring because termites may enter through them.
8. Eliminate access/ entry points of termites
Termite may enter through access points around dryer vents and air conditioner condensation pipes. This moist environment is a warm welcome for termites.
  For more information see gharexpert.com website safety section and termite sub section.
2499
Protect your Home from Bugs
Last answer on 12/29/2010 2:52:39 PM. by Nikita. Forum started by trimbak
3880
4925
LOAD BEARING STRUCTURE
1940
2132
For termite control
Last answer on 7/14/2018 9:59:57 AM. by kmiller1987. Forum started by ARVIND GOYAL
2675
Termite Treatment
Last answer on 9/25/2020 2:58:44 AM. by S L Gupta (Civil Engg). Forum started by Hidayath
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
1958
2897
Terrace water proofing
2767
2233
4736
2289
chowkets
Last answer on 9/16/2021 10:06:13 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2873
Types of Cement
6466
2144
i need the term related with damp proof and its treatment
Last answer on 8/29/2012 5:01:18 PM. by S L Gupta (Civil Engg). Forum started by abhijeet joshi
2035
Dear Gupta sir,Can you please suggest the detailed specification for a good foun
Last answer on 5/8/2013 12:14:58 PM. Forum started by nithun
2236
1890
2355
Refinish a Vinyl Floor
2521
Introduction
1088
Home appliances
2370
2964
layout plan
2182
Window Curtains For Home
3426
Reg: Interior design software
4764
2719
Living Room Decoration Ideas
2238
2034
2212
floor tiles
797
Online dating
2543
4041
Paint vs Wallpaper
2528
Design for a pooja room
9541
Wall Putty and primer
Straight Drop Awnings
2754
Kids Room Theme
2019
sapty tank
Termite
Termite Control
Have you protected your home from termites? Termites destroy household articles and create unhygienic conditions for i..
Termite
Termite Damage Signs and repairing tips
Termite damage is a worst dream for any house owner. Termites eat wood and this affect almost every wooden product lik..
Damp
Damp Proofing
Termite Control
Designing
Designing a Foundation
Termite Treatment for windows- Precautions and tips to remember
Termites are major wood destroying insects. We must take every precaution while doing any construction. Here are few t..
Protect
Fire
