Home -> Forums -> Construction -> Outdoor -> foundation plan.
foundation plan.
Thu Dec 15, 2011Total posts : 3
Patrick Salasini
Patrick Salasini
Topic: foundation plan.
i have a problem im putting up a foundation near a swampy place and the trenches are filled with water on the lower side. the soil is more of a riverside.
Please advise on how you can put up
Patrick.
Tue Dec 20, 2011Post  #1
ravi at Dalmia
ravi at Dalmia
Hi Patrick, making a home near a river body is always a risky matter. The soil as you rightly pointed out will be swampy. The foundation in this case becomes very essential for a sustainable home. An expert advice would be what you need before you go for it. Ask the expert if the soil can sustain the weight and weather the foundation will be affected or not. Good luck.
Wed Dec 21, 2011Post  #2
suhas
suhas
Post subject: Is it Most required
Patrick ,
Is it Most required to construct structure nere water side/Rever side ? ...........
Pl. GO ahed with End Bearing Piles  WITH Good Consultant
Fri Dec 30, 2011Post  #3
Ishmael Mphande
Ishmael Mphande
Hi Patrick
I am sure u can make it. Do as if u are extending your foundation and make sure you lay some pipes which will be used to continuously drain water from the area. Your foundation and slab work should include reinforcement b metal bars and mesh. Ask some technical help from someone technical near you how best to set these tools.
1924
1050
1873
2056
Last answer on 4/6/2016 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by zakia sultana
1691
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by JAI PRAKASH. Forum started by sushantsah
724
Hi sir,I have already make a foundation so I need
Last answer on 7/3/2020 10:30:07 PM. Forum started by Malik
4235
2307
4931
3857
2483
Pile Foundation
2404
Last answer on 11/18/2013 10:57:21 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
1906
Last answer on 11/18/2013 10:38:53 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
6500
2139
1454
Map for house construction from foundation to 3rd floor need house plan
Last answer on 11/28/2016 1:23:47 PM. by S L Gupta (Civil Engg). Forum started by anuradha
2176
I plan to start new house, which type of foundation is best for home.1.asthivara
Last answer on 4/4/2015 1:14:31 PM. by S L Gupta (Civil Engg). Forum started by ananth
2943
Need suggestions
2844
Steel calculation
1744
6661
6302
11322
10592
Life span of RBC lintel roof
2080
Foundation
3558
R.C.C. column in Sqft
2268
Plumbing works
1568
2130
New 4 storey building design
1881
earth filling under floor
1763
want a parking
2385
2255
2607
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2489
Re-Construction
2991
cracks in walls
Designing
Designing a Foundation
