Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> frame structure over existing load bearing masonry wall
Thu Mar 10, 2016Total posts : 4
navneet
navneet
Topic: frame structure over existing load bearing masonry wall
what happened when modify frame structure over existing load bearing masonry wall G.F. house .
Fri Mar 11, 2016Post  #1
Dear Navneet
     Your query is not clear. Write in detail what type of information do you need.
Sat Mar 12, 2016Post  #2
navneet
navneet
thanks sir for reply my query is ............
existing ground floor residential house, load bearing wall (no column,no beam) with R.C.C. flate roof
(1) can it convert it into R.C.C. column,beam for upper floor (I mean first floor) ?
(2)if yes,what can I do?
please answer in details with map and sketch also.
thanks in advance
Attachments: 101.pdf Sat Mar 12, 2016,&n
Mon Mar 14, 2016Post  #3
Dear Navneet
         Why you want column? Construction walls on the wall and lay slab as your ground floor walls are load bearing.
Tue May 03, 2016Post  #4
You can go with the same type of construction for the FF as well. Or you can add columns to your construction from GF but that would damage the GF Flooring and increase your costing.
2210
2524
2616
COLUMN nd LOAD BEARING
7256
8848
Last answer on 10/15/2014 1:52:38 PM. by SANJAY DUSANE. Forum started by Ambuj
1746
7925
4925
LOAD BEARING STRUCTURE
1763
3001
House Estimation Breakdown
3012
4128
10046
1878
column
2131
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by S L Gupta (Civil Engg). Forum started by Syed Shahed
2183
3218
2056
Bedroom Flooring
Last answer on 1/29/2012 11:18:07 AM. by greatwindowsss. Forum started by Suresh Kumar Regmii
6531
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by S L Gupta (Civil Engg). Forum started by DK
5810
3792
9883
2670
4626
4142
2865
5006
3655
1864
2799
2609
2372
2462
2637
1807
3607
6253
Door
Door and Window Frames
Earthquake
