What is the function of granite in concrete conpare to sharp sand?
Fri May 27, 2011Total posts : 1
onims
onims
Topic: What is the function of granite in concrete conpare to sharp sand?
Sat May 28, 2011Post  #1
Dear Onims
        To get desired strength of cement concrete mix, the constituentes material proper ratio is necessary. As sand have less crushing strength in comparison to granite. Hence the strength of concrete is reduced.
1460
2242
sand alternate for concrete
6450
2062
cement : sand:stone ratio
3272
For Estimate
2300
Looking for architect with experience in Function Hall plans
Last answer on 2/15/2022 5:04:04 AM. by JAI PRAKASH. Forum started by faiz
3469
Cost of concrete walls
2745
3713
2012
coarse aggregate
3589
Per Sq:ft rate for flooring
2679
2051
kitchen slab
Last answer on 10/1/2021 1:38:44 AM. by Jam117. Forum started by ARVIND GOYAL
2537
Function Hall
3643
I OWN 1000 SQ FT..IS IT POSSIBLE TO CONSTRUCT FUNCTION HALL WITH GOOD PARKING FA
Last answer on 8/3/2013 6:49:43 PM. by Navneet Jharia. Forum started by KRISHNA
6128
Function hall
Last answer on 10/4/2021 2:49:58 AM. by Lola Cooper. Forum started by Siddharaj
why we use granite for our home and kitchen ,,
Last answer on 1/30/2014 2:34:24 PM. Forum started by Nikhil rao
2198
Usage of M-Sand in Bangalore
Granite
Granite Countertops
A kitchen equipped with granite countertops looks amazing and improves the beauty of kitchen and your home as well. Th..
Concrete Decor
Concrete Mix Ratio
Purchasing Guidelines for Marble and Granite Stone
Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface.
Ready
Ready Mix Concrete
Balcony
Balcony is an extended platform that projects from a wall(interior or exterior) of a building, supported by columns an..
