For gate post, 13.5x13.5 Brick work with 4.5x4.5 rcc core is better or 6x6 Iron
Thu Nov 21, 2019Total posts : 2
Surinder Singh
Surinder Singh
Topic: For gate post, 13.5x13.5 Brick work with 4.5x4.5 rcc core is better or 6x6 Iron
For gate post, 13.5x13.5 Brick work with 4.5x4.5 rcc core is better or 6x6 Iron square pipe? the base is 9x9 rcc beam and two 12mm rebars per post are kept
Fri Nov 22, 2019Post  #1
Dear Surinder Singh
              For gate post 13.5 x 13.5 brick pillar with rcc core including 2 nos 12 mm dia steel bars in rcc is the best option.
Fri Nov 22, 2019Post  #2
Surinder Singh
Surinder Singh
Post subject: Thank you for reply.
Thank you for the reply.
- Surinder
main gate
Last answer on 6/16/2015 4:45:50 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
Shuttering Plywood
Last answer on 12/4/2011 6:16:40 PM. Forum started by Girish
35233
2154
4067
2500
images of iron gate attached to main door
Last answer on 11/18/2013 4:05:44 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
2520
Cement
2898
self made steel home
Last answer on 5/28/2012 8:26:15 AM. by smithjames758. Forum started by Govind.s
3483
labour charges rates
2529
construction const
2907
RCC Roof
3169
Last answer on 7/31/2020 7:39:42 AM. Forum started by Prahbjot Singh
2916
Shuttering Plywood
Last answer on 11/17/2009 9:26:16 AM. by Girish. Forum started by Girish
2426
4142
1711
4238
labour rate
2997
2162
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
England~Usa~Canada~Uae 91- 8769373431 husband wife (divorce) problem solution ba
Last answer on 1/3/2025 12:42:34 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:28 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:22 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:16 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:42:09 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:40 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:27 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:21 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:41:12 AM. Forum started by rupeshji
Isthikhara For ((Australia=London))08769373431 Love Marriage Problem Solution Sp
Last answer on 1/3/2025 12:40:48 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:42 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:35 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:26 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:20 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:13 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:06 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:40:00 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:39:54 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:39:41 AM. Forum started by rupeshji
Last answer on 1/3/2025 12:39:34 AM. Forum started by rupeshji
Checklist
Checklist for Painting Work
Post
Post Painting Works
Wrought
Wrought Iron Furniture
Wrought iron furniture is perfect blend of art and beauty. It’s one of the most popular choices of service providers a..
