Achieve a good quality in ‘Plastering’ Unique 'Plastering' makes a difference and requires a lot of skills which are discussed here.
| Tips for Cement Paint Cement paint perks up exterior surfaces and maintains good looks of a building for many years. It offers matt finish o.. |
What is the recommended thickness of the under and the top layer of terrazzo tile flooring? The under layer is made up of cement concrete in 1:2:4 Ratio (1-Cement,2 corse sand, 4 stone aggtregate ) and is aroun.. |
| 4 Tips to Decorate Entrance Doors Most of us think of designing or decorating our home from inside and spend thousands of rupees on interior decoration .. |
VASTU SHASTRA Vaastu Shastra is an ancient system of designing the buildings. It helps in maintaining a dynamic balance between Form.. |
Inconvenience When Good Material and Skilled Plumber Are Not Arranged for Water and Sanitary Fittings. A skilled plumber is required to implement proper water supply lines, drainage and sewerage lines. Good quality materi.. |
