Ground work
grade of concrete
grade of concrete
Sat Aug 02, 2014
Topic: grade of concrete
Sir
I could like to know what is the grade(M-15,M-20,or Higher grate) for design of column.
Sun Aug 03, 2014
Ahmed
for column minimum grade is M20 according to IS 456:2000 standards
Tue Aug 05, 2014
M-20 is the best
11587
Last answer on 3/25/2010 6:08:56 PM. by
ch jaya bharath azad
shridhar
32559
Cost of RCC Pillar
Last answer on 2/23/2022 11:59:24 PM. by
Subhajit Kundu
2318
cement
Last answer on 8/25/2012 12:33:40 AM. by
Ar. Manoj Ralen
abhijeet joshi
1740
Last answer on 7/4/2020 4:27:11 AM. by
Anu Mohan
1648
concrete grade
Last answer on 12/24/2015 4:21:52 AM. by
Rohit Sharma
1400
Last answer on 9/16/2018 10:58:39 PM. by
Vineeth V
6617
Last answer on 1/7/2022 1:25:49 AM. by
Girish
Girish
1766
vishal Thakur
1460
vishal Thakur
1765
Stair Grade Beam
Last answer on 3/30/2017 12:59:46 PM. by
Sanzana Hosen
1755
biggest confusion
Last answer on 12/29/2015 12:52:15 AM. by
sushantsah
2692
302 vs 304 grade steel for ralling
Last answer on 3/20/2015 9:55:35 PM. by
Type of Cement
Last answer on 4/22/2021 5:20:49 AM. by
sumit dua
2695
Last answer on 7/16/2020 11:56:35 PM. by
RAVISHANKAR
3469
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
3948
Cost of construction of RCC Piller with Foundation
Last answer on 4/22/2014 11:15:43 AM. by
Subhajit Kundu
2414
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
2413
Last answer on 10/12/2014 8:50:05 PM. by
sakthi
2276
swarup chakraborty
2995
Karan
8159
software
Vaasku
sco4666
sagar suryawanshi
2730
Manish Singh
1833
lanterns
ARVIND GOYAL
3133
false ceiling
sabita laskar
2245
about construction
simran
1786
lowz
4153
Cement Coba
Last answer on 12/21/2021 8:15:49 AM. by
Prasenjit
3076
Water Harvesting System
sunny420
1676
Robert
1758
water tank
rodmotall4
sadanand
2058
sumit
1760
jitendra kumar
1634
Pool construction cost
Erling
Shardul
1993
sanyindias
2738
Regarding roof beam
Amit Kumar
Fire Stair case
mvxmanazxmfsm
tejas
2645
MOHD WAKEEL
2371
super structure
anil kumar
Concrete Decor
Concrete Mix Ratio
Types of Cement
Ready Mix Concrete
