Fri Sep 07, 2018Total posts : 3
Vineeth V
Vineeth V
Topic: What grade of reinforcement bar is most commonly used for homes
Mon Sep 10, 2018Post  #1
          These bars are generally used
Reinforcement bars in accordance with standard IS No. 432 part-I can be classified into following types.
1) Mild Steel Bars: Mild steel bars can be supplied in two grades
     a)Mild steel bars grade-I designated as Fe 410-S or Grade 60
     b) Mild steel bars grade-II designated as Fe-410-o or Grade 40
2) Medium Tensile Steel Bars designated as Fe- 540-w-ht or Grade 75
Fri Sep 14, 2018Post  #2
Muhammad
Muhammad
Post subject: Thank you
Thankyou Gupta sir
I bought Fe 415 TMT bars, is this better or same like the bars:
you mentioned
Sun Sep 16, 2018Post  #3
          If taken from repudiated manufacturer Fe 415 Tmt bars is best.
1255
1175
1622
1272
3039
use of tmt bar
1193
How do Engineers calculate the Reinforcement needed for house. Is it possible to
Last answer on 9/25/2018 11:57:50 PM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
2695
2319
cement
Last answer on 8/25/2012 12:33:40 AM. by Ar. Manoj Ralen. Forum started by abhijeet joshi
1256
Is HYSD steel bars still used for construction. Do they meet the safety standard
Last answer on 1/10/2019 12:18:04 AM. by S L Gupta (Civil Engg). Forum started by rinu
2036
2707
2302
2033
3041
2898
RCC Roof
1682
earthquake safe building
Last answer on 5/12/2015 2:55:33 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2507
1508
TORSION REINFORCEMENT
Last answer on 4/15/2016 2:02:52 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
17
Types of Cement
HSD
Type
TMT
Hard
Skylight
