Is ground water from bore well suitable for construction?
Fri Sep 09, 2016Total posts : 1
Sandeep
Sandeep
Topic: Is ground water from bore well suitable for construction?
Fri Sep 09, 2016Post  #1
bhuvaneshwaran bn
bhuvaneshwaran bn
Post subject: As far as it is Free from chemicals and alkalies
Ground water from borewell is also Suitable for construction as far it is free from Mud,vegetation,Chemicals,Alkalies Etc..To put it simple it should be nearly drinking water.
Alkalies can cause Mild Steel to Rust.
chemicals/vegetation Affect the structure-water leakages in future
Please Correct me if i am wrong as i am open for the Opinions.
5031
pls sent a suitable front elevation for 20x60 ground and first floor building
Last answer on 1/22/2022 12:11:35 AM. by bablu suthar. Forum started by naga
2616
COLUMN nd LOAD BEARING
1595
Checklists for flooring
Last answer on 4/4/2015 7:09:35 PM. by JAI PRAKASH. Forum started by MUTHU
1834
Last answer on 4/6/2017 10:05:57 PM. by Saurav anand. Forum started by prashant
2180
pile work
2650
I am Sharath my date of birth is 15 Oct 1993 which direction suitable for study
Last answer on 12/23/2020 11:56:31 PM. by Abhishek Vohra. Forum started by sharath mb
2763
1871
1774
3903
construction of 1st floor
10048
1320
My plot is west north mouth.... it is suitable for construction home...
Last answer on 3/21/2016 10:41:32 AM. by S L Gupta (Civil Engg). Forum started by Bholanath.Poudyal
1714
Small size baathroom design required
Last answer on 1/10/2016 9:03:40 PM. by JAI PRAKASH. Forum started by Rohit
5056
1784
i am born in 08/04/1988 pls inforn how to i work in office and how to lead life.
Last answer on 5/12/2015 2:39:04 AM. by JAI PRAKASH. Forum started by shivaprasad
3163
APP membrane
1480
24
28
Preliminary
Vastu for Water Tank
Water for Construction
Various
Importance
Specification of Water
Clean and clear water is quite suitable for construction work.
General
