hello sir, how to remove cement stains on stone/rock where i want to keep them n
Tue Oct 27, 2009Total posts : 1
mallikar
mallikar
Topic: hello sir, how to remove cement stains on stone/rock where i want to keep them n
hello sir, how to remove cement stains on stone/rock where i want to keep them naturally with out plastring them . what chemical should use to remove the satins which are not so dangourshanking you
Fri Oct 30, 2009Post  #1
kapil
kapil
Post subject: Methods to remove stains from floor
Try these methods to remove cement stains from floor
  1. Clean the stained area with water and scrub with brush and this simple process may eliminate the stains.
  2. Clean the stained area by using chemicals, mix one part muriatic acid with 4 parts of water, make sure that pour the acid into water. Scrub the stains with solution and bristle brush, than rinse completely with water. If stains remain, reapply the solution and rinse until you remove it.
  3. The other chemical option is to apply cleaners containing phosphoric acid. Mix one cup of ammonia to one gallon of water and spread over the stained area and scrub with coarse brush.
Hello sir.... which cement is good one for foundation? plz suggest me
Last answer on 1/18/2017 12:00:26 PM. by S L Gupta (Civil Engg). Forum started by sharath
2624
About Rock in plot
Last answer on 12/1/2020 4:20:58 AM. by S L Gupta (Civil Engg). Forum started by madhu
2053
Ideal place to keep Mandir / Pooja ghar
Last answer on 3/27/2015 9:49:44 PM. by Pavan. Forum started by Taneesha Keer
5578
Flooring
Last answer on 2/24/2022 11:40:25 AM. by mike. Forum started by swati
7005
2003
Yellow patches coming in granite
Last answer on 2/25/2022 1:47:02 AM. by S L Gupta (Civil Engg). Forum started by sam_m400
2603
hello;i have only one room where to keep cash box exatly pleease suges methank y
Last answer on 3/17/2021 6:20:01 AM. by Sushit Choudhury. Forum started by rafimeer
1406
sir, what is the costing of tandur stone?
Last answer on 4/2/2017 7:48:45 PM. Forum started by gautam
25607
CURING TIME FOR RCC ROOF
1915
acid wash
Last answer on 3/24/2014 1:45:01 AM. by Purvi Panchal. Forum started by Mrs Francis
2063
cement : sand:stone ratio
3272
For Estimate
2587
flooring
Last answer on 5/31/2012 7:13:24 PM. by watson. Forum started by pallubc2
2695
1766
1538
hello sir can u have a any type of interior work
Last answer on 2/2/2022 2:59:44 PM. by S L Gupta (Civil Engg). Forum started by puran jangir
1252
3056
Vastu home map east facing plot 25 * 28
Last answer on 10/8/2015 11:39:50 AM. by Amit Hasija. Forum started by sudipta sinha
1674
Last answer on 11/15/2016 11:30:27 AM. by Beenu Phogat. Forum started by Heeralal Chowdri
Carpet
Carpet Cleaning Tips
Decorate
Appropriate
Colors
Colors of Kota Stone
Kota Stone is a natural stone found in attractive, beautiful and eye soothing natural shades of greenish blue and brow..
Advantages
Surface
Garden
Garden Path Ideas
Italian
Italian Marble Flooring
