Home -> Forums -> Construction -> Start Construction -> help for a drawing of house
Fri Aug 22, 2014Total posts : 1
tarvinder sahni
tarvinder sahni
Topic: help for a drawing of house
Hello i had a plout which is around 1800 square fit area (40×42) in hindi 202 gaj and i want to construct mine home and i want suggestion from u all how and ahuold occupies this area singel floor in which i want to make one drawing room 2 bedrooms bathrum attached kichen one store can anyone plz draw  map and hepl me
Mon Aug 25, 2014Post  #1
After
completion
of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
1164
1771
I want expert help on drawing directions of my flat and advise on vastu set up
Last answer on 7/6/2015 10:18:12 AM. by seema tyagi. Forum started by Jugal
a plot of 15×60 two room set + drwing+ lobby
Last answer on 5/10/2016 7:25:53 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:25:56 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:25:58 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:25:59 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:26:01 PM. Forum started by Sanjay arora
1718
South face 20*60 site I want to 2bhk and 1bhk house drawing
Last answer on 11/5/2016 12:34:13 PM. by Beenu Phogat. Forum started by hanumanth
3789
Dear Sir Please help my House plan plot area 10 x 22.5 feet
Last answer on 8/4/2016 5:24:14 PM. by S L Gupta (Civil Engg). Forum started by Gopal Upadhyay
1911
need help/advice to construct residentail house on 100 sq yd plot in hyderabad
Last answer on 2/21/2017 12:44:08 PM. by S L Gupta (Civil Engg). Forum started by Kamal
1825
Hey my plot size is 77×25 1750 sq ftPlz help me for house plans
Last answer on 3/31/2017 11:59:03 AM. by S L Gupta (Civil Engg). Forum started by sanjay chourasiya
2320
3134
i built one house so pls help me 27x42 sq feet
Last answer on 12/23/2011 5:00:58 PM. by FARZAN. Forum started by suryaprakash
2531
need paint in my house so wants to see a demo of drawing room how it look after
Last answer on 7/3/2020 10:09:31 PM. Forum started by muddassir
2869
1970
can we make drawing room in semi basement of a North east facing house.
Last answer on 12/31/2020 2:46:20 AM. Forum started by harbans singh sekhon
2299
i have north facing house plot can i make drawing room in north-west and car par
Last answer on 10/10/2009 7:12:24 PM. by Sudha. Forum started by hetal
3125
i want some samples house map 25X45(2bedroom,kitchen,drawing room)please send me
Last answer on 7/20/2015 12:01:25 PM. by seema tyagi. Forum started by mulchand
4532
help me to House Plan for 15 Feet by 45 Feet plot
Last answer on 9/25/2014 9:59:48 AM. by seema tyagi. Forum started by Gaurav Tiwari
2451
3274
3285
4429
3975
2197
2699
4210
5168
2378
2294
1996
2447
2114
3195
2047
12514
2164
2010
2726
How to design a house on theme
Theme designing is slowly but steadily picking up steam. Designers today are very particular about the 'idea' behind a s
Painting
Environmentally
Environment
Environment Friendly Houses
Interior
Interior Decoration Ideas for Drawing Room
The space matters a lot while decorating a room. Before decorating and furnishing your room, decide how much time your..
